I have a particularly interesting question...
How possible it is to extract a die from its molded package? Say, an 8P DFN.
Essentially, 2 things must be guaranteed:
1. No die surface damage
2. No bonding pad (Al) dissolving
Since the bond wire is copper, I'm sure it will be dissolved as part of the leadframe dissolving process, so I'm pretty sure I don't have to yank it manually.
I'm open to specialty solvents (Dynaloy 711/Decap/etc.), acid (hot H2SO4, warm HNO3, mix), milling and a mix of them. Cost is not a concern as long as in a small batch run, the cost per die is less than $10.
I can just buy the die I'm interested, but the price from Micross is not what I would like to pay ($50+ per 1.0mm*1.2mm opamp die).
FWIW, the post process after decapping is bumping with a gold ball bonder, then reflow with a gold friendly solder.
