Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Diode datasheet - so which is A and which is K?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Diode datasheet - so which is A and which is K? (Read 1276 times)
Circlotron
Super Contributor
Country:
on:
July 21, 2016, 02:03:03 am »
http://www.smc-diodes.com/propdf/SDUR6030W%20N1270%20REV.-.pdf
The drawing has no labels for A and K or 1 & 2.
I would presume the pin that also connects to the centre leg is the cathode because it connects to the heatsink surface like a double diode common cathode does.
Logged
Audioguru
Super Contributor
Country:
Re: Diode datasheet - so which is A and which is K?
Reply #1 on:
July 21, 2016, 02:22:49 am »
Missing important information. What do you expect? it is Chinese. The person translating the datasheet into Engrish knows nothing about electronics.
Logged
alsetalokin4017
Super Contributor
Country:
Reply #2 on:
July 21, 2016, 02:34:37 am »
Maybe they "assume" that the prospective user knows that the Pin 1 of a TO-247AC package is the one on the left as you view the front of the package.
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #3 on:
July 21, 2016, 03:40:27 pm »
Radial packaged diodes (including TO-247 and 220 styles) are usually anode on right, cathode on left (viewed from front, leads down).
It could always be reverse polarity, so if you must use it, get samples first...
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Mechatrommer
Super Contributor
Country:
reassessing directives...
Reply #4 on:
July 21, 2016, 03:51:50 pm »
to where the red probe read 0.7V
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
