I have 3 large MOT's (two are identical) that I'd like to repurpose for a 1KVA isolation transformer (see pic's). I really do not want to mess with the primary windings.. In fact, I will add a spacer and more insulating varnish to seal them off. I've been testing primary current with a 50-watt 1-ohm resistor to get some data. For the secondary's, I've been using 2 x 300-watt 6-ohm resistors.
1.) H-4.12" x W-3.45" x D-2.64" stack, center leg W-1.375" x H-2.04" primary amps@ 122vac 5.47 (4.69 with shunts) (10 Lbs.)
2.) H-4.12" x W-3.45" x D-2.64" stack, center leg W-1.375" x H-2.04" primary amps@ 122vac 5.47 (4.69 with shunts) (10 Lbs.)
3.) H-4.12" x W-3.45" x D-2.36" stack, center leg W-1.375" x H-2.04" primary amps@ 122vac 5.04 (3.76 with shunts) (9.1 Lbs.)
Originally, I was hoping to use just the first two in series on 122v mains, but even without shunts, the idle current seemed low at just 659mA (61VAC per primary). In that 2 transformer configuration, I put 7 turns of 14 guage cable on each and breifly shorted them to observe the primary current rise to just 5.1 amps, so I have a hunch I'll need more primary voltage. I also have 240VAC in my shop, so I'd like to add the third MOT (9% smaller) so I can run each primary at 80-VAC. I'll test again at 240v (without shunts) at no load, and with 6 turns on the larger MOT's and 5 on the smaller one to observe more idle/peak-current data...
The final project will NOT use the shunts and be housed in a heavy metal cabinet, fused, thermostatically protected, fan cooled, and use a timer to switch off mains after max. 30-minutes. Comments and test directives are welcome! Thanks.
