Author Topic: Op Amp array IC  (Read 6372 times)
Offline fonographTopic starter
  • Country: at
Op Amp array IC
« on: August 03, 2018, 11:28:52 am »
Is there some IC that have huge number of tiny op amps? The more the better.
Offline MT
  • Country: aq
Re: Op Amp array IC
« Reply #1 on: August 03, 2018, 12:46:22 pm »
I dare to say no since i also want tiny opamps for making 2 pole PWM filter buffers.
Online Siwastaja
Re: Op Amp array IC
« Reply #2 on: August 03, 2018, 01:08:28 pm »
Application-specific, very expensive arrays do exist. If you are after general purpose and low cost, it's hard to beat using cheapest jellybean quads or duals in the smallest SMD package you can find.
The following users thanked this post: fonograph
Offline JPortici
Re: Op Amp array IC
« Reply #3 on: August 03, 2018, 01:15:03 pm »
i'm afraid so :(
i was able to find 8/16 channels buffer amplifiers that in reality were just common colloctor buffers. Pity.
I am sure there are some strange unobtainable automotive parts but that is not of help.
Offline b_force
    • One World Concepts
Re: Op Amp array IC
« Reply #4 on: August 03, 2018, 01:21:30 pm »
Well with an opamp you always need 3 connections.
So the amount of pins adds up.
Depending on the application a DSP would be an easier choice nowadays.
Offline JPortici
Re: Op Amp array IC
« Reply #5 on: August 03, 2018, 01:24:30 pm »
with a buffer you only need two pins. bonus if placed in a logical manner like ULN2003
Online RoGeorge
Re: Op Amp array IC
« Reply #6 on: August 03, 2018, 01:25:16 pm »
There is something like an FPGA, but with configurable op-amps instead of configurable logic. They are called FPAA.
https://en.wikipedia.org/wiki/Field-programmable_analog_array
The following users thanked this post: b_force, fonograph
  • Country: at
Re: Op Amp array IC
« Reply #7 on: August 03, 2018, 02:13:06 pm »
OMG YESSSSSS! Thats exactly the kind of thing I was looking for,thank you so much  :)
Offline b_force
Re: Op Amp array IC
« Reply #8 on: August 03, 2018, 02:33:42 pm »
Good thinking!  :-+
  • Country: at
Re: Op Amp array IC
« Reply #9 on: August 03, 2018, 02:41:54 pm »
Does anybody know which FPAA can have most op amps active at same time? I would prefer to have ball grid array with gazillion bajillion metrik funktonillion pins for maximum number of active op amps at same time.
Offline b_force
Re: Op Amp array IC
« Reply #10 on: August 03, 2018, 03:10:09 pm »
What do you actually need to do with all these opamps?
Offline Benta
Re: Op Amp array IC
« Reply #11 on: August 03, 2018, 04:13:15 pm »
The company best known for this kind of thing is Anadigm.
No affiliation.
  • Country: at
Re: Op Amp array IC
« Reply #12 on: August 03, 2018, 05:19:16 pm »
I would prefer to avoid disclosing that information. 8)
