Nothing illegal at all about it.
Surge generators are valuable to test engineers. As far as I know, there are no laws restricting their availability or use. (Being test equipment, their price alone probably keeps enough people away.
In strong contrast to biological, chemical and mechanical weapons, electrical systems just don't offer enough power density to be a credible threat.
Even rail guns have taken many decades to be realized, on naval ships at that.
The same drawback undermines the realization of practical battery-powered electric vehicles (which are weapons all their own, and regulated to a modest extent -- depending on country). The power and energy density isn't there. Which is not to say they're impossible -- we have real, economically viable examples (well, give or take EV and emissions incentives) today -- but
they will always be at a disadvantage to fuel-air powered machines.
Lab-scale EMP test systems don't fit in a rackmount box, or even a handful of full-height rack cabinets. It's more like, the lab itself must be constructed around the pulse system!
AFAIK, the basic design is to discharge a high voltage capacitor into a network; like any other surge generator system. The network has to be constructed to deliver the desired field strength and waveform, usually to meet a particular standard (such as nuclear EMI, fast or slow type, or explosive-compression or solar storm sources).
The laws of E&M guarantee that, anything you try to generate from an antenna, either requires an impractically massive antenna to produce a directed beam of energy, or requires the target to be very near (or within) the antenna. (Nuclear weapons have the advantage that, by ionizing a layer in the atmosphere, they drive a current through a wall of plasma, using the atmosphere as the antenna itself.)
