Author Topic: Where to find motor replacement?  (Read 17385 times)
Offline eTimesVTopic starter
« on: February 22, 2024, 11:01:35 pm »
I picked up a small, used Inland DB-100 diamond-bladed bandsaw to cut glass for ~$20.  The motor unfortunately overheated and literally blew up with a poof and puff of smoke.  The replacement  motor seems extraordinarily expensive ($130) for what it is and in any case out of my budget:
https://inlandcraft.com/products/band-saw-motor?variant=31631567126641
Can anyone suggest where I might find a suitable replacement?  There is a small custom motor controller board inside, not sure how big a role that plays in finding a 100% exact match motor.
It has brushes (see pic) but says 240AC on the name plate so I guess it's an AC and not a DC motor?
I would think I should be able to find a little motor like this for maybe $20-30.
Looks like the shaft is 8mm and sticks out ~23.5mm. Motor diameter ~76mm, length 107.5mm.
Name plate on motor:
Model IPPM9801-240
Volts 240AC
RPM 3000
Amps 0.5
Torque 0.213Nm
No. 32CY990502-265
Made in China
Googling "IPPM9801 motor" didn't turn up much. If I do an image search there's nothing at all, a completely empty Google results page. I tried variations thereof like with/without "-240".  Also no luck searching on Alibaba or Aliexpress.  Also searched IPPM9501 and IPPM9301 (two possible variations when you look at the image of the name plate where one digit is overwritten by hand) and adding the search hint "motor" or not, nada.  I also tried searching based on the specs and didn't find much.  It's a little strange to come up so empty.  This comes close in some respects
https://leisonmotor.en.made-in-china.com/product/sXAQqBSKSjUM/China-Small-PMDC-High-Speed-Zyt-DC-Motor-78mm-Dia-with-8mm-Shaft.html
but is too small and I'm not sure if it works with 240VAC and anyway I've never been able to order from Alibaba without being asked to pay $70-100 shipping.
  So, I thought I'd ask for advice here.
Offline DTJ
Re: Where to find motor replacement?
« Reply #1 on: February 23, 2024, 01:23:56 pm »
Not a direct replacement but looking at that motor I'd consider replacing it with a treadmill motor and controller.
I often see them either thrown out on the verge or being given away on facebook.
An added advantage would be variable speed.
The following users thanked this post: Solexx
« Reply #2 on: February 23, 2024, 05:09:13 pm »
Thanks for the suggestion.  I rarely see those being sold or disposed of where I am but I was thinking if I really can't find the equivalent to maybe try something like
https://www.aliexpress.com/item/1005006358641757.html but now that I look I see shipping makes that too expensive too, and I'd have to ditch the existing housing and design/print something new which I'd rather avoid if I can.
The existing motor is variable speed, at least with the attached controller/pot.
« Reply #3 on: February 27, 2024, 10:31:25 pm »
Given the lack of replies I feel like maybe I'm posting in the wrong forum.  Anyone know of a better one?  I can think of one, practicalmachinist, which I will try next but any other suggestions?
Offline Benta
« Reply #4 on: February 27, 2024, 10:52:23 pm »
I think it's more astonishment over "cheepness" here.
You made a steal with 20 Euro bandsaw, and now you're complaining about a 130 Euro motor? If it's that bad, throw the whole thing in the trash.
Concerning Practical Machinist: forget it. Anything China and you're out faster than you came in.
Offline mikerj
« Reply #5 on: February 27, 2024, 11:05:35 pm »
It's a DC motor since it has permanent magnet fields, applying AC to this would just make it hum loudly and start smoking after some time.
Offline temperance
« Reply #6 on: February 27, 2024, 11:31:53 pm »
From the looks of it seems something on the PCB went up in smoke and the motor itself might be fine.
Some species start the day by screaming their lungs out. Something which doesn't make sense at first. But as you get older it all starts to make sense.
« Reply #7 on: February 29, 2024, 10:07:20 am »
thanks for the reply.  Although the $20 was quite within my budget $130 is less so.
Sorry for not having more disposable income.
« Last Edit: February 29, 2024, 10:20:44 am by eTimesV »
Online coppercone2
« Reply #8 on: February 29, 2024, 10:11:04 am »
it might be sealed against dust and stuff its a dirty activity aka expesnive
« Reply #9 on: February 29, 2024, 10:11:56 am »
I forgot to add the pic but although there could be something wrong on the PCB too, the motor definitely has a problem.  This came out of the motor:
« Last Edit: February 29, 2024, 10:16:33 am by eTimesV »
« Reply #10 on: February 29, 2024, 10:19:20 am »
The motor is labelled "VOLTS 240AC" and, although I'm for sure not certain, the PCB doesn't really look like it is converting AC to DC.  Still, the brushes are confusing since normally you'd expect then it's a DC motor.  I guess maybe it's one of these https://en.wikipedia.org/wiki/Universal_motor
« Reply #11 on: February 29, 2024, 10:23:49 am »
That would make sense but having taken it apart I don't see much along those lines compared to other motors I've taken apart.  I suppose there could be something else special about it though.
Offline Zero999
  • 0999
« Reply #12 on: February 29, 2024, 10:48:59 am »
Does it have field coils or permanent magnets? Going by the picture it appears to have permanent magnets, so is a DC motor.
That's insulation from the windings.
My advice is scrap it, if you can get a cheaper one, than the price of a motor and parts for the controller, otherwise it still might be worth repairing.
I suspect the controller is also faulty. The fact it doesn't appear to be burned doesn't mean it works.
It's possible the controller caused the motor to blow up, although I would suspect it's the other way round.
Going by the photograph, the controller appears to be a phase controller. There will be four didoes (either discrete components or a bridge rectifier module), which converts the AC to DC for the motor, a thyristor (the three legged component), a DIAC (the blue cylinder) and a few resistors and capacitors. The TRIAC is the most likely component to fail, followed by the rectifier diodes.
« Reply #13 on: February 29, 2024, 03:02:58 pm »
I should have been more specific about the overheating in my original post....I was cutting a 22.5cm circle out of a 17.6mm thick piece of plate glass for a telescope mirror blank.
The saw manual didn't recommend cutting thick glass but didn't say why and I thought if I did it carefully it could work.  It actually worked really well, I went very slowly, lubricated the cut with a lot of water, but, 28min. into cutting the circle out the motor overheated and blew.  I know, 28min., loading a small motor like that, should've been obvious it's too much...well, hindsight's 20/20 and I was so absorbed in watching and guiding the cut I didn't notice the time.  If I replace the motor I will add a thermal cutoff switch attached to the motor body and a temperature sensor so I can see how it's getting as I cut.
  The motor was nuclear hot when I pulled it out.  Even close to an hour later it was still 56°C, see thermal pic.
The saw's normally $460 (https://inlandcraft.com/products/db-100-band-saw-with-diamond-blade?variant=31631547596913 230V version) so I'm going to continue to try to find an alternative replacement motor or eventually I might just buy the official motor if I can manage it.  I have a 750W ac motor with VFD that I could cobble onto the bandsaw drive mechanism which for sure will never overheat, but it's not ideal and I suspect it would just keep snapping blades rather than how it is now that the motor bogs down first during a slightly heavy cut, rather than the blade snaps.
« Last Edit: February 29, 2024, 03:06:42 pm by eTimesV »
Offline Zero999
  • 0999
« Reply #14 on: February 29, 2024, 03:34:21 pm »
It's still possible the controller is destroyed. Overloading the motor will increase the current draw, which might be too much for the controller.
Another motor and a VFD is a good idea. A decent VFD will enable you to limit the current, thus torque, which should prevent it from snapping the blade.
« Last Edit: February 29, 2024, 07:54:31 pm by Zero999 »
Offline pienari
« Reply #15 on: March 01, 2024, 07:37:13 am »
Why you just chance real ac motor.
Control with Variable Frequency Drive Inverter ?.
« Reply #16 on: March 01, 2024, 11:55:42 am »
Sorry, I don't understand what you're asking.
