Author Topic: DIY Metcal 13.56 MHz RF Supply  (Read 353021 times)
Online Monkeh
Re: DIY Metcal 13.56 MHz RF Supply
« Reply #425 on: March 28, 2016, 08:01:25 pm »
https://www.linkedin.com/pulse/diy-project-my-workshop-soldering-station-valeriya-p-
this woman has done the assembling of those 2 pcb's better and cleaner then most men's around here ...  ::)  ::)  ::)
Keeeeeeep digging.
Offline AndersAnd
« Reply #426 on: April 10, 2016, 08:17:39 am »
Anybody out here is thinking to re-design some part's of the pcb?(rf power supply)
I want to say that in the hakko fx100 we have the rf connector soldered directly in the part where the rf power output is.
In the diy metcal power supply we must to solder some kind of 75ohm of cable to make the connection over the iron handler and the power supply.
Is this a really good way to make less radio loss over the rf power connection?
because personally i think will be better to solder the connector directly on the pcb.
In this picture you can see what im talking about.
The link to the link to the image you posted doesn't work anymore. Looks like the direct link changes dynamically. Here's a new link:
And here's some more pictures: https://www.eevblog.com/forum/reviews/hakko-fx-100-any-good/msg772986/#msg772986
« Last Edit: April 10, 2016, 08:20:18 am by AndersAnd »
Offline AndersAnd
« Reply #427 on: April 10, 2016, 08:23:46 am »
Looks like it forum member hhw who made a post earlier in this topic: https://www.eevblog.com/forum/projects/diy-metcal-13-56-mhz-rf-supply/msg813905/#msg813905
Same avatar at LinkedIn as here in the forum:
Offline timofonic
  • Eternal Wannabe Geek
« Reply #428 on: April 10, 2016, 09:22:51 pm »
This project is buried in tons of posts.
 Any hero willing to summarize it? If possible, what about asking a forum administrator to put a first post here with such information?
Offline Iwanushka
  • Country: lt
« Reply #429 on: April 26, 2016, 07:50:12 pm »
maybe someone has spare boards?
When all you've got is a hammer, everything starts looking like a nail.- Attrition.
The following users thanked this post: Wolfram.Chrome
Offline Iwanushka
  • Country: lt
« Reply #430 on: April 26, 2016, 08:53:56 pm »
Iwanushk is that you from dangerprototype which unisolder 5.2 project ?
LOOL
Yes, that's me!
Offline Iwanushka
  • Country: lt
« Reply #431 on: April 27, 2016, 12:26:50 am »
LOOL
Yes, that's me!
U r AWESOME :)
All I did was sell some surplus boards, that's all, all the credits go to sparkybg
Offline timofonic
« Reply #432 on: April 29, 2016, 09:44:11 am »
Are there schematics and PCB files about this project?
Do UniSolder by sparkybg supports RF soldering irons too? Last time I checked seems didn't support them. Please correct me if I'm wrong ;)
« Last Edit: April 29, 2016, 09:51:33 am by timofonic »
Offline AndersAnd
« Reply #433 on: April 29, 2016, 11:56:05 am »
No.
Unisolder forum thread at dangerousprototypes: http://dangerousprototypes.com/forum/viewtopic.php?f=56&t=7218&p=61175#p61175
« Last Edit: April 29, 2016, 12:00:13 pm by AndersAnd »
Offline melgozan
  • Country: ua
« Reply #434 on: May 07, 2016, 10:01:26 pm »
Offline MRBadGuy
  • Country: aq
  • sometimes i feel like i break down and cry...
« Reply #435 on: May 10, 2016, 08:46:12 am »
I have a few questions ,as my english is not yet perfect,for me actually is not very easy to understand all this materials.
So let's start with some dumbass questions.
1)To power up this thing can i use an already made power supply ? maybe one like this ?
LRS-75-24
or is better to go with an simple power-trasformer?
2)Which power-trasformer i must to get ,something like this?
output : 30vac and 80va ? it must be less or more ?
3)In the original metcal the tip inside the hadler goes to sleep when the handler is inside the stand ,but here is the same as in the original metcal ?
Offline MRBadGuy
  • Country: aq
« Reply #436 on: May 11, 2016, 12:30:42 am »
Oh my GOSHSHSH !!!
no reply ,no one ,this for me looks like this project is almost more then death.
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #437 on: May 11, 2016, 06:45:01 am »
1, That type of power supply would work, the one in the photo is too small but LRS-75-24 would be enough.
2, The transformer I used was Farnell part number 1780865. 24 V 100 VA. There are plenty of other choices.
3, The magnetic stands saturate the tip and reduce the dissipation. That will work with this design if you use the right stand but you don't actually need to because this design uses directional couplers to detect forward and reverse power and the software on the PIC then makes a decision that the iron hasn't been used in a while and sets a low power mode. That mode keeps the tip cool for long life but is still hot enough that it can detect the heat loss (due to movement through the air) when you remove it from the stand.
There are PCB files and schematics available, they're attached way further back in the thread. I think many months ago and a couple of pages back there was a summary of what was on which posts.
The following users thanked this post: MRBadGuy
Offline MRBadGuy
  • Country: aq
« Reply #438 on: May 11, 2016, 07:53:21 am »
Oki thanks you for the informations.
But i have some last questions to do.
Is the owner of this project don't care anymore about it ?
Because he must to make an update of the RF exit way on the pcb, to solder an connector-plug directly on the rf stage.
This will make an perfect swr tunning over the Power-Supply and the iron.
For example watch out this guy from youtube min 0:27 to 0:31 :
as you can hear, he claims to have problems with the hadler and in my personal opinion that problem is started by a wrong swr tunning caused by
the cable soldered on the RF powersupply.
We really need that update (At least i think this way)
« Last Edit: May 11, 2016, 07:55:24 am by MRBadGuy »
Offline richard.cs
« Reply #439 on: May 11, 2016, 08:24:41 am »
I don't think that is likely to be a major problem. At these frequencies the odd impedance at the junction is only a very short length compared to the wavelength and it should really be fine. You could edit the files to add a connector footprint if you like but I am not convinced it will make a lot of difference.
Take a look at my page here: http://randomfunprojects.co.uk/metcal.html and look at the table near the top of the page, you'll see the SWR of the tips themselves is not great when cold, reasonable when warm, and (by design, to regulate the temperature) very high when hot.
Offline MRBadGuy
  • Country: aq
« Reply #440 on: May 11, 2016, 08:58:01 am »
Oki maybe you are right,but i still can't figure out why the iron hadler of that guy is getting so hot,it's obviuosly an issue ...
However if the DIY Metcal Station is abbandoned by the owner ,it's useless to waste the proper time here.
This makes me sad ,because i was in love with this project  :-BROKE
« Last Edit: May 11, 2016, 09:03:58 am by MRBadGuy »
Offline richard.cs
« Reply #441 on: May 11, 2016, 09:22:36 am »
I don't think it's been abandoned, you will get answers to reasonable questions if you're patient but I think most people won't bother answering things they know you could find just by reading through the thread. Set aside some time to start at the beginning and read it all, note down post numbers with anything that looks useful. All the information is here, you can take the schematics, the PCB files and the software, change if you want to, and build it.
The following users thanked this post: Iwanushka, MRBadGuy
Offline idpromnut
« Reply #442 on: May 16, 2016, 11:33:03 pm »
Thanks for linking my video on my build of the DIY Metcal (or MeltCal!). I know you wanted me to post my project however I'm not quite ready and there are a few things I wanted to get on video and photograph before presenting something here. I'm working on a new controller/PSU PCB (my build involves fitting the MeltCal into an radiation measurement instrument case that I bought off EBay) that will be AVR based, and is rather designed specifically for my build.
The other bit that I'm working on (slowly) is getting the v0.3 (plus modifications by Widlarizer(irc) in one of the feedback loops on the RF board) converted into Kicad along with a PCB layout.
@MRBadguy:
idpromnut: You sure can!
2)Which power-trasformer i must to get ,something like this? output : 30vac and 80va ?
idpromnut: I run my MeltCal at about 24-30VDC @ about 2-3A.
idpromnut: yes, but the catch is that the "mechanism" is in the hand piece holder, and not strictly in the RF board. The holder has a magnet near where the tip rests, and this changes the impedance of the tip which I believe makes the tip reflect more RF back to the RF supply which the supply detects and the built in feedback loop reduces the RF power to the hand piece.
« Last Edit: May 17, 2016, 02:17:26 am by idpromnut »
The following users thanked this post: Mephitus
Offline hurtmanissimo
  • Country: ru
« Reply #443 on: July 20, 2016, 11:42:06 am »
Pack in enclosure.  only turn knob not yet installed.
Metcal clone
Metcal clone
Metcal clone
Metcal clone
Metcal clone
Metcal clone
i`m use 26v spsu because large transformer eat alot of space, and it will not fit in that enclosure perfect :)
still not solve problem with large talon tips :(
they heat up, but build huge amount of reflected voltage, then irf die after overheating. (current consumption around 2.8a)
Offline Deaniture
« Reply #444 on: October 23, 2016, 11:09:11 pm »
I don't know whether this thread is still alive, but I was wondering if there were any boards available from the masterful creator of this project. This MX500 supply is something I would really like, only the real ones by Metcal are extortionately expensive.
Kind regards
D
Offline Deaniture
« Reply #445 on: October 25, 2016, 01:19:00 pm »
Also, if the creator of this project is no longer on this forum, and there are no boards left, I would quite happily be willing to get a small production run made for anybody interested?
Offline richard.cs
« Reply #446 on: October 25, 2016, 01:26:14 pm »
mamalala is still on this forum occasionally according to his user page: "Last active 2016-10-13, 08:51:25" In the past he's been happy for people to get boards made, there have been at least three batches over the lifetime of this thread.
You'll probably have to hunt through the thread to get the latest build files but all the information is in there.
Offline Deaniture
« Reply #447 on: October 25, 2016, 01:38:24 pm »
Yes, thank you.
I have just had a chat with him, and he has no more boards left. I have had a look through the more recent posts, and people don't appear to have made any in any significant quantity. I will have another look but, as I say, I would be happy to make a small run of boards/kits if people were interested.
Thanks
D
Offline wkb
« Reply #448 on: October 26, 2016, 08:18:09 pm »
Yes, thank you.
Thanks
D
I have a bare board set from him sitting in my stock here somewhere. In the meantime I have found myself a 2nd Metcal unit so this board set is surplus to requirements.  Let me know if you want them, I paid EUR 10 for them, plus the stamps for shipping
The following users thanked this post: Deaniture
Offline cwalex
« Reply #449 on: October 28, 2016, 11:20:00 am »
I would be happy to go in for a PCB or kit if you end up getting some boards made.
