I've almost finished everything needed for the waveform generator / frequency counter as far as schematics go, with the electronic load and lab power supply not far behind. Depending on how things progress I might have stuff on GitHub this weekend.
One thing I've settled for is using 3.3V for the logic and +/-3.3V for the analog stuff where digital isolators aren't used, the only exception being the AD603 used to adjust the output amplitude of the waveform generator's output for sine/triangle which requires +/-5V, delivered via a pair of LM317L/LM337L off the +/-15V supply of the output stage.
As far as the electronic load and lab power supply are concerned, they're 80% done unless I find easy ways to add more features which I've been doing a lot lately at the expense of them not being finished yet (like another multiplexer for the option to measure all the internal supply rails).
Oh, and it's 80% of the schematics, PCBs not included.
Speaking of PCBs, that's another can of worms since it's about a dozen of them... almost:
- UI board
- Waveform Generator & Frequency Counter
- Lab Power Supply
- Electronic Load
- Front Panel & Aux Digital Channel
- USB Charging Module
- USB - UART interface
- Aux Analog Supply (linear regulators - easy)
- Aux Digital Supply
Ok, it's only 9 of them.
Another thing I have planned for sometime in the future is an ethernet module based on some PIC18 and Microchip's TCP/IP libraries but I'm not going too far with it from the start and I'll probably base it on an existing example.
One thing I still have to look into is whether I can reuse the Front Panel module designed to be used with the lab power supply for the electronic load as well, without the relays used to switch the two channels between independent/series/parallel and for that I have to decide what the high current range will be and what connectors I'll use and whether they'll be PCB mounted or panel mounted. Looking for parts is very time-consuming, especially when I'm trying to stick with only 2 distributors - TME & Farnell. Digikey and/or Mouser will have everything anyway but shipping cost will be higher for me at least.
If anyone has any comments or questions or pretty much anything related you can leave them below. Blame the way the forum works if they end up on the next page (joking).
