Haven't worked on any part of this project at all for a few days and that's when ideas start coming and it's time to start tweaking.
I was looking for parts on Farnell/element14 website and found out they have a lot of quadrature rotary encoders to offer which made me want to change things a bit, forget the Bourns PEC11-L which is available at distributors which have high shipping cost to my country. Alps seem to have some nice encoders at a decent price also with included push option so I'm going with one of those. $5 shipping is the same as TME charges. If I can stick to these two distributors I'm happy and so far they seem to have all the parts I need.
Speaking about tweaking the designs I'm starting to think the UI board doesn't need a SEPIC converter if I use a charge pump to generate the -5V rail on the lab power supply board instead of an inverting DC-DC converter which would have used the LT3580. The charge pump wouldn't be a big deal as I could just use some logic gates driving small dual MOSFETs and clock them with the SYNC signal. That would eliminate the requirement for coupled inductors which aren't as easy to get as regular ones.
The LT3580 would be then replaced by the LT3680 which is also used on the aux digital supply board, reducing the BOM count.
With the waveform gen configuration being almost complete it's time to focus on the next two groups of modules I have planned, the DC Load and lab power supply and sort out the mechanical aspects.
Since I want the DC load itself to be modular there are two possible setups:
- Have the modules in parallel for more power
- Have the modules grouped and isolated from each other, like a multi-channel power supply
The first setup can contain a local microcontroller (on the DC load PCB) or not. The micro would be used for constant resistance or constant power modes. Paralleled modules will share a single DAC .
The second setup will include some form of isolated DC-DC converter and logic isolators.
For the lab power supply things will be a bit simpler, each power supply module is going to have an isolator+ADC&DAC board on top of it.
Another piece of test equipment that I intend to design and build, another module in this case, is a mains Wattmeter.
