Author Topic: What is an injection channel used for in a SAR A2D?  (Read 7916 times)
Offline SuzyCTopic starter
« on: September 07, 2014, 08:10:21 pm »
The PSoC4 MCU's have SAR's that have multi-channel input and one injection channel.
ummm...whats that for?
Offline nuno
  • Country: pt
Re: What is an injection channel used for in a SAR A2D?
« Reply #1 on: September 07, 2014, 08:33:32 pm »
They explain that in one of the docs. Basically and if I remember correctly, you can have the ADC automatically doing readings round-robin on a set of channels. It happens that sometimes you want to do an odd reading on channel which is not part of the set, or a channel you want to just read at a much lower pace; the hw allows you to do this, to inject a one-time "foreign" channel reading in the reading loop programmed in the hw.
« Last Edit: September 07, 2014, 08:35:25 pm by nuno »
« Reply #2 on: September 07, 2014, 10:04:08 pm »
Thanks nuno, for the explanation, it will help me to work with this a2d module.
