I decided to build one this morning. It took a *lot* longer than I expected. I still haven't calibrated it yet.
It's made of material on hand:
1/2" EMT (electrical conduit)
1/4" - 20 5" carriage bolt
two 1/4" - 20 Tee nuts
#10 - 24 screw and 3 nuts
small piece of cold roll 1/4" x 1" steel
spring and a glass marble
A couple of mistakes I made to watch out for. When you squeeze the tubing in the vise, pay attention to the weld and make certain it is on the minor axis of the ellipse. When fitting the jaw, use an actual SMA connector, not a #10 - 24 nut. The offset on one side is the result of my cutting the jaws too wide and then forcing them back together with a hydraulic press. It worked a bit more than expected. The pivot was not quite properly centered so the action is asymmetric. It has the best release when the offset of the jaw is on the bottom.
All the work was done with a drill press, hacksaw and files. I made threaded spacers by rounding #10-24 nuts with a file using a screw in the chuck as an arbor. I did the same for the Tee nuts to get them to fi the tubing. The innermost is a close fit and the outermost is a press fit. I drove it in with a deep socket and a hammer as it was too tall for my manual arbor press.
While the EMT works, it's rather heavy. Aluminum tubing would be nicer. This was all done by eye. The distance from the pivot to the marble should be smaller. That will allow more error in the centering of the pivot hole. Once I'm sure I don't want to tak it apart again I'll center punch the EMT either side of the outermost Tee nut.
Edit: In playing with since posting, I think the marble needs to be a closer fit in the tube and that that is what is causing the asymmetric release. The marble is 0.560" and the EMT is 0.620" ID
