In my attempt to be
as cool as robrenz (yeah I know I'll never get even close) I'd like to build a similar enclosure.
These male to male Pomona triax cables.
These female bulkhead connectors.
The tip of the bulkhead connectors would terminate to the same Tyco connectors used by robrenz, the guard connection left unconnected.
And some all aluminum enclosure, haven't decided on the exact model yet. A couple questions, in terms of low noise performance:
1 - Does the size of the enclosure have any effect? I'm not thinking coffee table size, but perhaps a cigar box size?
2 - Exterior conductivity? Even though this will be sitting on a proper antistatic mat, would a painted or otherwise non conductive exteriour offer better low noise performance?
3 - Probably my main question, with the bulkhead connectors above, this setup would ground the outer shield on all 4 connections together at the AL enclosure, instead of the somewhat normal just force low shield.
Aside from the triax price robbery, what do you guys think?
