For note 2: if I have a big enough input voltage, say 30V, and I use a 1:0.5/0.5 (half split secondary) transformer or a resistor voltage divider, I could just split the input voltage in two and as such create +15::0::-15 before I use those SMPS modules. If I use a transformer there I could also use a 1:2 winding to create 30V (still split as 15+15) or so from a merely 16V input. Did I get this right?
For note 1: I should convert a buck configuration into an inverting configuration. I don't think it's easy doable, and most inverting designs I seen on application notes of LM2576 (and similar) report that I could only go up to 700mA current, by far less than 2A. Also, I would not really get to use 2A, but I'd feel better to know I have the little extra just in case.
EDIT
still about note 2: the thought might be correct but I get a lot of current loss since output power must be equal to input power. Supposing I have 15V input at 4A and I want 30V output (half split, but still 30V total), then the output current is (15V*4A)/30V = 2A.
Since I want to use 19V @3.5A power supplies that come with laptop PCs, it puts me down on using a transformer to double the output voltage... any ideas?
