uh then how could you distill stuff? that's only true if it forms a azeotrope.
Actually no, it's true all the time.
There is a common misconception that when you distill things, "the lightest substance distills over first", as if first the lightest thing boils off as a pure substance, and then the next thing boils, and so forth. This is a bit of an oversimplification and it is not exactly what happens. The reality is more complicated than this simple picture implies.
What really happens is that the whole mixture boils, but the vapor coming off is richer in the lighter components than the liquid left behind. In a distillation apparatus the vapor is made travel up a column (maybe the long neck and glass tube attached to the flask in a laboratory apparatus). As the vapor travels up this column some of it condenses and falls back down while the rest of the vapor travels upwards as the temperature falls. By the time the vapor reaches the condenser it has ideally fallen to the boiling temperature of the substance you want to collect (a thermometer is used to check this). At that point what you condense should be your nearly pure product. But this only works if you carefully control the boiling rate and the condensing temperature.
On the other hand, if you simply make a mixture of water and alcohol and boil it in an open vessel (danger, do not do this indoors), the vapor that comes off will be a mixture of water and alcohol too. You will not be able to achieve any meaningful separation by this means.
