As long as you run each bus through the correct pair of cables (ie the ones twisted together) then i'm sure oyu won't have an issue, especially down at just 20kbaud.
CAN gets bundled up, un shielded in much worse conditions than those existing in a Cat5 cable with CAN running on the other cables!
I guess you can't just up the baud rate, because that's the easiest option to get a higher throughput?
