I bought one of the cheap ATMEGA LCR transistor testers off eBay more than a month ago. There's several threads about these devices on the forum.
Only 4 AUD! Ended up being too good to be true. I received only this:
A
case for an LCR-T4.
The item description on eBay never specified a case. It only showed pictures of an actual LCR-T4 unit and the description is for the real item. When I asked for a return eBay immediately refunded me -- I wasn't even given the option of asking for a resend. I guess eBay has finally worked out that many sellers completely ignore your message and resend the wrong item again if you try xD
"It might only be a problem with one seller". So I bought two more from two different sellers.
Guess what arrived.
Yep.
Different international packaging. Same wrong item. And of course neither package has any information I can use to work out which eBay seller is which.
TheoryEach case is in a resealable bag with an identical "SeeBee" sticker on it. I suspect that someone (SeeBee?) has sold these cases to the sellers with the wrong information (pre-made ebay description?) attached. The sellers have probably copied and used this template directly, without even looking at the items. The bags do say "LCR-T4" after all.
I've now bought an LCR-T4 for 15 AUD. Let's hope a real one arrives. If I get another SeeBee bag....
