Author Topic: driving 3 phase brushless motors  (Read 3971 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: September 20, 2018, 11:16:35 am »
I am looking at this catalogue: https://www.parvalux.com/media/wysiwyg/Resources/Catalogues/Parvalux_-_Brushless_Catalogue.pdf
In particular at the PBL86-91. I've never worked with these motors before but from the information given driving them is as simple as switching the phases high and low for the listed outputs of the sensors? is it that simple? not proper sine waves required?
Offline MrW0lf
  • Country: ee
    • lab!fyi
Re: driving 3 phase brushless motors
« Reply #1 on: September 20, 2018, 11:22:38 am »
You PWM voltage to get semi-sinusoidal current. Thats why they squeal like pigs at low RPM when there is no BEMF to smooth things out.
  • Global Moderator
« Reply #2 on: September 20, 2018, 11:30:13 am »
yea that is what I meant, so basically by high and low they are referring to the polarity of the sine wave.
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #3 on: September 20, 2018, 11:41:13 am »
...and if you get PWM wrong its trouble because impedance of the windings is non-existent. Hardly any inductance at all - was quite surprised when measured them first time. So better start playing at veeery low voltages :)
  • Global Moderator
« Reply #4 on: September 20, 2018, 11:44:12 am »
even better to get an off the shelf controller but I need one for automotive not a pansy industrial controller that won't take the 250V spikes and 40V surges.
Offline Benta
« Reply #5 on: September 20, 2018, 03:32:21 pm »
You have to think about it like this:
A BLDC works exactly as a PMDC motor. The only difference is, that the brushes and the commutator have been replaced with electronic switches.
This also means you have the same switching pattern as with a PMDC, meaning only two phases are active at any time.
For speed control, you can start adding in PWM, but that's on top of the basic operation. This is also where the "squeal" issue comes in, otherwise BLDCs are very quiet.
Offline langwadt
« Reply #6 on: September 20, 2018, 03:49:26 pm »
yep, I've seen a BLDC driver that had a switching voltage regulator feeding the switches instead of doing PWM
  • Global Moderator
« Reply #7 on: September 20, 2018, 05:37:05 pm »
Indeed, our motor and driver supplier at work was proposing just such a scheme because it meant that he could do the PWM at the most efficient point and reduce peak currents in the stator coils.
Offline Benta
« Reply #8 on: September 20, 2018, 06:27:21 pm »
There are two basic schemes for BLDC control:
1: varying the supply voltage to the power stage, either DC or PWM
2: gating a PWM signal into the drive circuit for the power stage.
In both cases, the "Master" signal for the power stage drive is the feedback from the Hall sensors.
The opportunities for adding advanced features on top of this are of course infinite.
  • Global Moderator
« Reply #9 on: September 20, 2018, 06:40:56 pm »
Yes but if you are having to approximate sine waves with PWM how do you decide on the cycle length of the sine? do you base it on the last known time taken to go between the previous phases?
The other thing is can't you just send the motor a sine wave and know the rotor will follow it round particularly if it's something like a fan? I can understand that something like a traction motor requires feedback.
Offline langwadt
« Reply #10 on: September 20, 2018, 06:57:41 pm »
you can run it open loop just like a stepper motor, that's how sensor-less start up
but you have very little torque and you can't go very fast before the slightest disturbance makes gets the rotor out of sync
and it stops turning
Offline Benta
« Reply #11 on: September 20, 2018, 07:11:57 pm »
Stop, stop, stop!
Please reread reply #5.
Sine waves do not come into basic BLDC drive at all. It's bang-bang commutation, just like PMDC.
Now, you can try fiddling with making pseudo sine waves for a BLDC drive, but it's not really worth the effort.
Sine wave generation comes into play when driving 3-phase PMSM, where all three phases are active at any time. The motor is basically the same, but the drive strategy is completely different. It's an open-loop drive where speed is controlled using a constant U/f ratio. For certain applications it can be attractive (very precise constant speed), but is complicated and a lot of bother.
  • Global Moderator
« Reply #12 on: September 20, 2018, 07:18:13 pm »
what is PMSM? The motors I am looking at are 3 phase although as you say only 2 phases are active at a time.
U/f ratio?
Offline langwadt
« Reply #13 on: September 20, 2018, 07:23:01 pm »
Stop, stop, stop!
doesn't seem much different than running  a stepper motor full-stepping vs. micro-stepping
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #14 on: September 20, 2018, 08:09:20 pm »
Think he means this?
Offline langwadt
« Reply #15 on: September 20, 2018, 08:17:36 pm »
that's BLDC, PMSM is similar but the winding are spread out so the back-EMF is sinusoidal instead of trapezoidal
Offline Benta
« Reply #16 on: September 20, 2018, 08:29:50 pm »
My apologies for using an acronym, I normally tend to avoid this, as it can lead to confusion and misunderstanding. This time I fell into the trap myself.
PMSM is " Permanent Magnet Synchronous Motor".
It is basically the same motor as a brushless DC motor, but the drive strategy is completely different. Three-phase AC is supplied to the motor, mostly in the form of PWM.
Torque/speed characteristics are also completely different, as it's a U/f (or V/Hz) drive.
This as opposed to a brushless DC motor, which behaves exactly as a brushed DC motor.
MrW0lf, your schematic shows exactly the commutation of a BLDC motor. The trapezoidal waveforms come from the motor inductance and are very idealized in your graph, but still representative.
Offline Benta
« Reply #17 on: September 20, 2018, 08:46:33 pm »
Simon, check out the graph from MrW0lf and you'll see the following sequence from 1...6 (the lowest three traces):
A - B - C
+   0   -
+   -   0
0   -   +
-   0   +
-   +   0
0   +   -
Do you see what I mean when I say only two phases are active at any time? This is the commutation pattern of both a PMDC and a BLDC motor.
  • Global Moderator
« Reply #18 on: September 21, 2018, 06:27:51 am »
I thought PMSM meant that really it's the difference between the two that is the confusion.
So do off the shelf chips exist that take care of everything if I supply the power stage? well I know they do exist but is this something worth considering or is it a custom program on a micro controller?
Offline MrW0lf
  • Country: ee
    • lab!fyi
« Reply #19 on: September 21, 2018, 06:54:46 am »
Here is some old thread I found about BLDCs, maybe something useful:
https://www.eevblog.com/forum/projects/is-there-any-_easy_-way-to-do-brushless-dc-motor-speed-control/
BTW initially when mentioned squealing, and being careful with PWM I was actually thinking PMSM. But was little disoriented because some refer to brushless outrunners also as BLDCs, now if think about it's of course PMSM because BEMF is sinusoidal and drive is crazy PWM. But for example Hobby King never names them PMSM. Did get one little bugger (Turnigy 2730-1300) from drawer and measured: L=~36uH, R=0.37ohm, Z=0.43ohm @ 1kHz. Essentially rotating resistor :o
« Last Edit: September 21, 2018, 06:56:53 am by MrW0lf »
Offline Benta
« Reply #20 on: September 21, 2018, 06:40:58 pm »
There are lots of chips out there that will:
1: understand the inputs from the Hall feedback sensors.
2: provide drive for your output stage in the correct sequence.
3: accept a PWM input for speed control.
Many will have additional features like current monitoring, UVLO etc.
A search for "brushless DC motor drive IC" should give plenty of results.
TI is an obvious place to look.
Offline IDEngineer
« Reply #21 on: September 21, 2018, 08:50:17 pm »
Not all such motors have Hall effect sensors. Some use the BEMF from the inactive phase to track the rotor's position and time the commutation. It's a juicy little problem because the BEMF sensing circuitry has to be able to withstand the MUCH higher driving voltage.
Yes, there are off-the-shelf IC's that handle BLDC motors, including those without integrated Hall effect sensors. Many/most are primarily logic/timing, and expect 1-3 driver chips (or at least discrete FET's) between them and the motor to handle the higher voltage/current side of things. This can be a deep rabbit hole... very interesting but set aside a fair amount of time if you really want to get into it!
Offline Benta
« Reply #22 on: September 21, 2018, 09:04:06 pm »
IDE, if you'd care to read the original post, it already links to a motor in question, which has Hall feedback...
Just trying to raise the signal/noise ratio.
Offline IDEngineer
« Reply #23 on: September 21, 2018, 10:10:52 pm »
Agreed, but "understand the inputs from the Hall feedback sensors" could mislead someone into presuming that all such multiphase motors have integrated Hall effect sensors. I was trying to add data - raise the S/N ratio, so to speak - not contradicting you.  :)
« Last Edit: September 21, 2018, 10:12:38 pm by IDEngineer »
Offline james_s
« Reply #24 on: September 22, 2018, 05:21:47 am »
There are several open source firmware distributions for speed controllers used in RC aircraft, lots of schematics out there too. Most of these motors are sensorless but the sort used in RC cars typically have hall sensors. Looking at that firmware should give you some clues on how it works.
