OK, I thought I'd understood how this motor works, but clearly, I don't. Anybody have any clues?
The label information is thus :
DC Brushless motor
SIC-55CVL-F159-1
DC310V 8P
58W E Class
Wires are Vm, GND, Vcc, Vsp, PG
It is brushless motor, I'm presuming it has a controller board inside as this would be ultimately driven by AC. 8P I imagine means 8 Pole so that looks like 24 poles in total for three phases? The DC310V ... I have a hard time believing that it requires 310 volts DC. 58W would make sense to be 58 Watts. I don't know what 'E' class means.
What does NOT work is Vm at 12VDC, Vcc at 5VDC, and Vsp pulsed at anywhere from 10Hz-8Mhz with any duty cycle. I have noticed that PG will have a 'noisy' spot and a 'quiet' spot in the slight pole positions as one rotates the motor.
Picture is below too.
