Recently I am playing with some temperature sensitive things so I think I can use TEC coolers to heat or cool the sensitive part.
In this case, 0C~30C is fine, so I do not need accurate temperature control. However, I do need a simple and low cost solution.
My question is, can I connect a TEC rated for maximum 3.6V into a 5V system, and drive it with unfiltered PWM? The 5V can be lowered to minimum 4.5V, but that is still more than the TEC's rated max voltage.
