Author Topic: DRV2605 LRA auto-resonance calibration  (Read 2383 times)
Offline dingariTopic starter
« on: October 09, 2017, 06:49:16 pm »
Hi, I'm trying to get an LRA haptic actuator to work with TI's DRV2605L driver chip. The actuator is a C10-000 from Precision Microdevices.
I've successfully completed the calibration step described in the DRV2605L datasheet, but the haptic effects are weak, and the waveforms don't look like the ones in TI's setup guide. So, there is something I'm overlooking. I'll share the source code of my calibration routine implementation below.
bool DRV2605L::autoCalibrationLRA(float v_rms, float v_peak, float f_lra) {
    // This procedure is described in section 8.5.6 of the datasheet
    // Step 1. Power on device and pull EN HIGH (done prior to calling this function)
    // Step 2. Place device in auto-calibration mode
    writeByte(DRV2605L_REG_MODE, 0x07);
    // Step 3. Populate the input parameters required by the auto-calibration engine
    uint8_t feedback_val = 0;
    feedback_val |= (1 << 7);  // Set LRA mode
    feedback_val |= (2 << 4);  // Set Brake Factor to 2x
    feedback_val |= (2 << 2);  // Set Loop Gain to high
    writeByte(DRV2605L_REG_FEEDBACK, feedback_val);
    // Set rated voltage register value
    float sample_time = 300 * pow(10, -6);  // Sample time, default value 300 us
    float v_avg_abs = v_rms * sqrt(1 - (4 * sample_time + 300 * pow(10, -6)) * f_lra);
    uint8_t ratedv_val = (uint8_t) ((v_avg_abs * 255) / 5.3);
    writeByte(DRV2605L_REG_RATEDV, ratedv_val);
    // Set overdrive voltage clamp register value
    uint8_t overdrive_val = (uint8_t) ((v_peak * 255) / 5.6);
    writeByte(DRV2605L_REG_OVERDRIVE, overdrive_val);
    uint8_t ctrl4_val = 0;
    ctrl4_val |= (3 << 4);  // Set auto cal time to 1000ms (min) to 1200ms (max)
    writeByte(DRV2605L_REG_CONTROL4, ctrl4_val);
    // Set drive-time to a half-period of the actuator
    uint8_t ctrl1_val = 0;
    float period_lra = 1.0 / f_lra;
    uint8_t drive_time = (uint8_t) (((period_lra * 1000.0 / 2.0) -0.5) / 0.1);
    ctrl1_val |= (drive_time & 0x1f);
    writeByte(DRV2605L_REG_CONTROL1, ctrl1_val);
    uint8_t ctrl2_val = 0;
    ctrl2_val |= (3 << 4);  // Set sample to 300 us
    ctrl2_val |= (1 << 2);  // Set blanking time to 25 us
    ctrl2_val |= (1 << 0);  // Set idiss time to 25 us
    writeByte(DRV2605L_REG_CONTROL2, ctrl2_val);
    // Note: ZC_DET_TIME bit is set to 0 (100 us) when control reg 4 is written
    // Step 4. Set the GO bit to start auto-calibration process
    writeByte(DRV2605L_REG_GO, 1);
    while((readByte(DRV2605L_REG_GO) & 0x01) != 0) {
        // Wait for GO bit to clear, as that indicates calibration complete
        nrf_delay_ms(2);
    // Step 5. Check the status of DIAG_RESULT bit
    uint8_t status = readByte(DRV2605L_REG_STATUS);
    return (status & 0x08) == 0;
I'm calling the calibration routine with these values: (2.0, 2.82, 205).
This is the output (my scope locked up every time I plugged my USB stick in, so please pardon the photo):
This is the waveform I'm expecting:
DRV2605 Datasheet
DRV2605 Setup Guide
Re: DRV2605 LRA auto-resonance calibration
« Reply #1 on: December 09, 2017, 12:11:23 pm »
I've resolved this now. I was writing the overdrive clamp value to an incorrect register.
