So I've been using an electronic cigarette to cut down on my smoking. It's helped quite a bit and I am enjoying it.
Having gotten into it, I do as many others do with just about anything else, and that is get on the net and start the research.
What I've found, is that a lot of people that have no clue about electronics are all of a sudden self proclaimed ee's because they learned ohm's law......
In any case, the actual subject matter of this thread is:
When 2 Li-ion cells are used in a device, it's recommended that they are "married", meaning they should be charged and used together for the life of the cells. This is mainly for safety of the user, device and cells.
Makes sense.
What doesn't make sense to me:
When these two married cells are charged, it is recommended that the cells position in the load are switched after every charge cycle.
As far I know, all these devices in particular that use two cells, the cells are either used in series, or parallel, in which case, I believe that if there is an internal defect in one cell, it won't matter which position it is in, in the device.
Please educate me further.
