Hi guys,
I've made a multiphase flyback power supply for a project that requires an adjustable, isolated power supply that charges capacitors with a voltage of 300V to 400V, with a maximum needed power of 250W. Basically a voltage limited current source. The flyback topology seems the best for me - it's pretty much a pulsed current source that I can enable/disable as I please using a simple feedback system, and I've managed to get up to a bit over 90% efficiency with three identical blocks working in parallel. That's a nice efficiency, but still there's a fair amount of heat coming of the thing - the outside temperature of the transformer maxes out at around 80-85 deg C at room temperature - and it's not going to be at room temperature, it's going to be enclosed, with restricted airflow... And I'd like to avoid adding forced air cooling. The transistors aren't very cool either.
I've checked the efficiency figures for flybacks and 90% is pretty good most of the time. Maybe I'll try using a bigger core, but that's a problem due to height. I've also been checking out toroids for flybacks - not exactly available are they? They would be great in that I could expose much more winding to the outside air and have a greater exposed surface area...
The input voltage is 48VDC, can be set to a bit higher (43VDC to 55VDC being the limits). With mundane parts, what kind of topology would you recommend for this task that would have the best efficiency? Or, better still, is there any kind of module that can do exactly this?
Thanks,
