Hi everyone, I'm making an electronic load using a microcontroller. I'm wondering how to implement the constant voltage, power, and resistance mode?
My problem is there's always a voltage drop along the conductor cables. If that happens, how do you truly get the desired output? For example, if I have a 5V input and I want a 1W constant power, I would need 200 mA. But at 200 mA, the voltage I measure is.. let's say 4.5V, making it 0.9W, even though the power supply is still outputting 5V. So, I am measuring 0.9W even though I am actually drawing 1W from the source. How do you get around this problem?
