Author Topic: ESD safe caps in series still ESD safe?  (Read 1174 times)
Offline MrMetthewTopic starter
  • Where it all comes down to : i = c (dv/dt)
« on: April 25, 2018, 03:50:55 pm »
Hi all,
I was wondering, if I put two esd safe capacitors (e.g. AVX ESD55C472K4T2A-18) in series to double the voltage rating of the cap, will they preserve their esd safe properties?
Online T3sl4co1l
    • Seven Transistor Labs
Re: ESD safe caps in series still ESD safe?
« Reply #1 on: April 25, 2018, 05:51:35 pm »
I don't see why not.
Seven Transistor Labs, LLC
« Reply #2 on: April 26, 2018, 07:53:50 am »
Maybe because the esr gets doubled? I am not sure..
« Last Edit: April 26, 2018, 01:38:37 pm by MrMetthew »
Offline jmelson
« Reply #3 on: April 26, 2018, 07:41:12 pm »
Hi all,
That's 4700 pF?  Geez, what's this ESD safe stuff?  I think it would be VERY hard to damage a 4700 pF cap unless your ESD conditions are so bad you are getting visible/audible sparks jumping around.  The really worst-case human body model has a 470 pF reservoir cap that is charged to the test voltage, this is worse than almost any real ESD event you can imagine in a station where exposed PC boards are handled.
Jon
Offline Niklas
« Reply #4 on: April 26, 2018, 09:33:00 pm »
The internal structure is slightly different on these capacitors to provide a discharge path that bypasses the wanted capacitance. Apart from that they are just like normal capacitors and can be connected in series or in parallell.
https://incompliancemag.com/article/effectiveness-of-multilayer-ceramic-capacitors-for-electrostatic-discharge-protection/
Offline wraper
  • Country: lv
« Reply #5 on: April 26, 2018, 10:07:09 pm »
They don't provide any discharge path. The difference is in placement of conductive plates.
