It could be due to too low switching speed of the diode. It is fast for low currents, but slower with higher current. When the regulator turns off the switch transistor, and the diode is not fast enough to turn on, then the inductor can create a voltage transient high enough to breakdown the switch transistor. The input voltage is already close to max, so your safety margin is low.
Google "diode induced failure linear". Linear has both an appnote and a video clip illustrating this issue.
