Hello,
sorry that I left you without any reply, but Christmas was coming and what's the point of contemplative christmas time without any stress?
First beginners error is not posting the schematic and telling us what you want to accomplish with it.
Yes, my bad. I attached screenshots of the block diagram and each schematic. I hope, that's helpful. The purpose is a universal soldering station, e.g. a station which can control several soldering irons from different manufacturers.
You use extremely small pads for some large components. And it seems C10 and C11 would be impossible to mount with such hole size and distance if silkscreen represents actual cap diameter.
I got the pad size for each copmonent from the data sheets. So if I made no error with centimeter and inches, it should work. Or do they seem that small?
The silkscreen of C10 and C11 should represent the actual size. So why does it seem impossible to mount them? I have not that much of actual soldering experience, so I' honestly not sure why it shouldn't work.
Here is a document on laying out pcbs with smps on them
Also, the time old favorite by the author of this website, Dave Jones himself
http://www.alternatezone.com/electronics/files/PCBDesignTutorialRevA.pdf
Thank you, I will read it.
I believe your green highlighted components means that they're colliding with another component. Have you run a design rule check?
Yes, there are components where Altium thinks they collide. For example the display, which goes over the entire PCB, but will be mounted on spacers. The problem is currently that I cannot set the rules matching the PCB mill, because my university couldn't say which mill I can use for making the PCB. But if I made no error while creating the components, there should be enough room for each component.
