Hi all.
This is my first post here, so please be kind.
I am a designer with 30 years of experience, mainly doing embedded controllers and some mixed-signal designs. I designed a very high-current motor control board for a battery-operated lift, which has been quite successful in terms of operation and reliability. At the time the design was initially started, FCC and CE testing were not a concern. Several years after the design was put into production, the product went through FCC testing, and with some tweaking (ferrite cores on the motor leads, and lowering the processor clock frequency), it passed.
Now the company is trying to get CE approval, and they have introduced another complication - they added a wired remote control tied into the existing front-panel control switches. The unit is failing CE radiated emissions, mostly in the sub-70MHz range. When the “pendant” is stretched out, the radiated emissions are much, much worse. I have been called back to see if i can help them fix this issue.
The first thing I want to do is to determine whether the radiation is coming from the H-Bridge FETs switching, or (as I am thinking), the broad-band noise from the brushed DC motor at 50-70 amps. The reason I don’t think it’s the FETs is: I modified a board with larger gate resistors and confirmed that the switching time was increased from 200nS to 500nS or so, and when the board was re-tested, they didn’t see any significant change.
I am proposing buying a Spectrum Analyzer and doing some basic scans to see if i can pinpoint the area where the noise is coming from, and when I do, using the SA to measure the effectiveness of any fixes I try. I have a number of questions about this (keep in mid that I am on a shoestring budget, under $2,000):
1) What SA to buy? I’m looking at the Siglent SSA3021X. If I’m going to spend the money on a new piece of test equipment, I’d like to buy the most capable machine. I’d like something that can measure above 900MHz, since I’m working with some ISM-band radios. I don’t know if it makes sense to get an SA that goes to 3GHz or more. There are some used machines on ebay that look good, but some of them are physically enormous (like an R&S FSB), and I’m concerned about buying someone else’s problem. What about the Anritsu MS2711D? There are several on ebay with warrantees, and they are cheaper that the Siglent.
2) What antenna to use? I’m not interested in spending a fortune for a bi-conic antenna. Also, those nice PCB antennas are all made for much higher frequencies than I’m concerned about. Should I just bare a piece of Coax? I don’t care about calibration, since I’m going to be making relative measurements.
3) How about near-field probes?
4) Can the Siglent still be unlocked? I’m on a budget, and having the EMC option would be nice.
I appreciate any insight into this that anyone can share.
