Hmm, I've hit a snag! Actually, two snags, but I sorted one of them already!
The contrast seems a bit off - looks fine when view it from above, but viewing it straight on or from below makes it unbearably pale.
LCD bias looks to be controlled internally from the
PCF8576 driver IC, so Im not sure how to fix it! Any suggestions
I can live with it, but its very, very pale when the backlight is on =/
As a side note, I discovered that if you put the polariser in backwards, it inverts the display, giving a black, opaque background with white, transparent text - which is a surprisingly nice effect! Reminds me of those midas transflective modules!
