Tonight I found
https://xdevs.com/article/f720a_res/I think P and N mean positive and negative tempco.
There are examples of designations after this letter being 0.5, 1, 1.5, 2, 3, 4
This is almost certainly PPM / deg.C
The 8375A DVM (1970's vintage) has R5 and R6 in series in the input divider network.
They are both 4.45 M ohm, one is GL1P4 and the other is GL1N4, giving a net tempco of zero !
Newer resistors seemed to be marked directly with tolerance +/-0.02% +/-0.01% etc
and don't have any codes like FL1 FL2 FL4 etc.
I think these are older Fluke internal codes that represent the construction / power / tolerance.
The first letters of codes I have encountered so far are:
E = Small tubular and mica former, approx 0.5 - 1W rating (?)
F = Medium mica former, approx 1 - 2W
G = Big tubular, approx 2 - 5W
Second letter and first digit:
H1, H2, H3, H4
L1, L2, L3, L5, L6
I suspect these relate to the tolerance, and are all below 1%.
