Though I mentioned this project in the new beginners 'The "I made this!" thread - Beginners achievements with pride.', this dedicated thread is for questions on how to build and use and modify the device.
Hi everyone. Got a strong amp with low frequency capability, but no sub-woofer, or need a batter active filter for your sub-woofer? I'm posting my full Subwoff project, one of my earliest home projects from the late 90s.
This was my first project using AdvancePCB/Schematic, which became Protel98/99se, and now is Altium, back in 1997.
It is a sub-woofer enhancement processor I called Subwoff. It takes line level in, allows you to boost 25/20/15hz and below to ridiculous gains with an inaudible soft smooth rounding clip function allowing you to boost your speakers/amp subsonic rumble for movies. Yes, the filter is so perfectly tuned that no bass will be added to the voice or music, just the rumbling effect. It is stereo and allows you the feature to turn off the main audio so you can also use it as a active sub-sonic filter for a dedicated subwoffer instead. Documentation and full schematic is in the .pdfs.
I've included schematics & CAD CAM GERBER files with BOM. It is a 2 layer board under 10cm X 10cm allowing for cheap 5$ prototypes for anyone who wants to build it. The .pdf files have hi-res versions of the full schematic and PCB. It requires a 9vac or 12vac output wallwart to opperate, not DC. All the 10uf and 1uf caps should be non-polarized.---------------------------------------------------------------------------------------------------------------------------------------------------
Major update - Feb 14, 2018. PCB and BOM redone with modern available components.
- BOMs now includes Digikey links and part numbers for everything except resistors.
- PCB is 10cm by 7cm. Now has mounting holes. 10mil space, 10 mil gap, 2 layers. All components on top.
- Schematic has been cleaned up with some additional descriptions.
- Except for 4 green leds at 0603, all other SMD parts are 0805 or larger. Easy to hand assemble.
- Dirt cheap to make them in China, PCBway.com quote on this PCB is 5$ us for 10 PCBs + shipping, 2-3 day shipping.
2 units built and tested - March 13, 2018 - Some minor patches.
- Switched 2 opamp gain resistors from 51k to 4.7k, WAY too much subsonic gain, this fixes it.
- Tented all vias
- Enlarged and relocated silkscreen labels for RCA inputs and 12VAc input.
- Recommend now at least 12vac, 14vac max.
- Added silkscreen description for the two 3 position switches. (Sorry, the only room was under the switch itself..)
- Regenerated Gerbers, schematic, previews.
Works amazingly good.
