I thought it was a ground and the little bit of metal on it was a contact going to the shaft so you wouldn't have to go through the bearings. Hey it even has a little green dot...
That green dot was a polarisation marking from when I pulled it apart, not knowing whether or not it was needed. I might stick to black permanent markers from now on.
Pretty bad! Is the crimp on the other fork as bad as it looks?
I'm assuming you're commenting on the very tight bend of the copper just as it leaves the crimp (I'm no crimping expert
) Yes they're both like that, but this part of the motor is stationary so it should not be too bad.
I've just had to regut the motor again twice. The first time because I scraped too much dirty grease out of the bearings without replacing it and the second because I had 'parts left over'. It's all working well now.
