Greeting EEVBees:
--I had pretty much decided that the capacitor plague was over after not having replaced a capacitor for lo these many months. Then, four projects in a row in the last couple of weeks have bad capacitors; 1) A Westinghouse 22" CFL LCD monitor, repaired. 2) A one year old LG Air Conditioner, under repair. 3) An 8 year old Dell motherboard, scrapped. 4) A Tripp-Lite 900LCD UPS, just now repaired and working.
--Below is some general advice for those who want to do multiple, many cap recapping projects. Also for those who want to work on expensive equipment belonging to someone else, without embarrassing themselves.
1) Use a good professional desoldering tool that has a vacuum pump, Hakko, Dennon or even one of the less expensive knock-offs. I use a Hakko 470, with the bench top enclosure holding the pump and PS, and the light weight Hakko 802 gun, all for less than $150, shipping included. It is a bear and it never picks up anything it is not supposed to. I have yet to buy a new tip. Hakko USA offers all parts at very cheap prices. Smart! Trying to use the old $5 bang stick and wick technique on crowded expensive boards with small through holes and unleaded solder is going to cause you to pull up a trace, suck up a via, short or ruin an SMD, or otherwise kill the patient. Also it can take forever going back and forth with the stick & wick and the soldering iron to re-wet the leftover unleaded with leaded. Unleaded solder can be a bit of sticky wicket. It does not like all come out. Using a DS gun you just hold the gun tip against the lead and hole an re-wet with leaded and immediately re-vac, done. Often components just fall out. One of these will definitely improve your confidence. 50 Capacitor Motherboard, no problem. Even Dave had to finally breakdown and buy one of these. Here is the link to Dave's Video;
http://www.eevblog.com/2013/11/01/eevblog-542-zd985-desoldering-station/. As you can see by Dave's video the Rhino works as well as the Hakko, but is more cheaply made, and the spring filter has a large hole at the pointed end, unlike the Hakko, and consequently drops solder on the ceramic fiber rosin filter, ruining it much faster than the Hakko. Also the Hakko has a red telltale on the side of the gun, that lets you know when the vacuum begins to drop. Still the Rhino indeed "works a treat", and Dave aptly demonstrates the utility of the device.
2) You will need a rigorous procedure to make sure you can get the replacement caps back into the correct locations. Photographs are helpful, but usually cannot see everything. You could just replace the caps one at a time, but often you have to remove some to identify them. And then what are you going to do? Re-install?? If you have only a few caps, a sketch will suffice, but it must be checked three times or disaster will result. If the cap numbers are marked on the board, my method is to remove the caps one by one and write C16 or whatever on the body of the cap using an indelible black marker, or white paint pen (see picture below), and one by one drop them into a labeled pill bottle. Also make sure the polarity of the caps are clearly marked on the board, or mark them yourself. I just blew one up this week, being inattentive.
3) When ordering replacement caps, I prefer Digikey, or Mouser if Digikey does not have. In addition to making sure that the capacity and voltage are correct, you will need to make sure that the replacements can physically fit. Sometimes you can go wider or taller, or lay the cap on its side, and sometimes you cannot, so you need to measure size. Digital Electronic Calipers (carbon fiber, see picture below) are way cheap on eBay and make things very easy compared to using a ruler. I usually just take the already labeled bad caps, one by one, and measure them for height and width as I am ordering them from Digikey. This way the Digikey order is the list, need not be put on paper. Then, one by one the bad caps are put back into a labeled pill bottle. If I have a mix of 25V and 16V caps of say 22uF, I often just order all 25V if they will fit, to shorten the line item list, and avoid errors. Often I order one more than I need of each cap value, just to cover screw ups, build an inventory, and spread the postage cost per item.
4) Once I discover a bad cap, I generally just replace all of the caps, except the large power supply filter caps, which are almost always OK. Sometimes I measure the ESR (using the AnaTek Blue ESR Meter which I love) of all the caps and make a chart noting also the Brand, Capacitance, Voltage, and Temperature, as I have done below with the 9 caps from the Tripp-Lite OMNI900LCD UPS. You can easily see the virtue of replacing all the caps. What is amazing is that the TRIPP-LITE UPS worked for the longest time with nearly all of the capacitors out of spec. This is a very typical situation, so if you have a non-working device, and you see a swollen cap, you can just replace all but the power filter caps, and Roberto es su tio.
NR = No Reading.
C1 Gemcon 85C 100uF 25V ESR 2.8 Bad. NR = No Reading. New Nichicon ESR is 0.09.
C2 Gemcon 85C 10uF 25V ESR NR Bad, the new Nichicon ESR is 0.07
C3 Gemcon 105C 680uF 25V ESR 0.12 Bad, the new Nichicon ESR is 0.01
C4 Gemcon 105C 680uF 25V ESR 0.24 Bad, see above
C10 Gemcon 85C 470uF 16V ESR NR Bad, the new Rubicon ESR is 0.04.
C16 Gemcon 85C 22uF 16V ESR NR Bad, the new Nichicon ESR is 1.6.
C17 Gemcon 85C 22uF 16V ESR NR Bad, see above.
C19 Jamicon 105C 1000uF 25V ESR 0.03 Good, but the new Panasonic ESR is 0.01.
C23 Gemcon 85C 22uF 16V ESR NR Bad, see above.
--Moral of story is Gemcon is Wun Hung Lo. Other than the bad caps the TRIPP-LITE OMNI900LCD UPS had only one small potential problem. One of the 3W resistors was stood on end to save room, and its inertial mass was causing it to rock and lift up the traces, creating a potential open. I traced out the connections and made the lead and trace more mechanically secure by bending over the soldering leads of a cap it is in parallel with, as it was too crowded to use glue on the top side. As a general matter I find that the quality of construction of the APC brand UPSs to be superior to the TRIPP-LITEs. In addition to using better caps, APC cleans their boards after soldering. With the TLs you have to clean the flux off of the board in order to inspect for bad joints. As uncle Wun Hung Lo once said on eBay "Happy for you to desoldering please".
"To learn who rules over you, simply find out who you are not allowed to criticize."
François-Marie Arouet - Voltaire
1694 - 1778
Best Regards
Clear Ether
