In spite of all the warnings I got the HT02 thermal camera from China. It isn't even the cheapest one any more, but it sure is bad:
Low resolution, long focus range and averaging in software makes it useless for all
microelectronic intents and purposes.
I think it uses a thermopile array sensor, but I didn't find any datasheet for it.
I've poked around a bit and found only 2 data lines: Blue goes low every 500 ms, yellow is 2400 varying pulses within every 500 ms window.
2400 pulses seem a little bit weird because the spec-sheet claims a resolution of 60*60 pixels. But then again the display is not square, so I could imagine it being a different resolution.
But how do they transmit the sensor data? I thought it might be as easy as pulse width representing each pixels value, but there was no noticable change when testing with a hot object.
I'll try to figure that out and then do something more fun with that sensor, but if anyone knows something ... lemme know
