Hi guys, first post, so sorry if i'm breaking rules or something of the like.
Anyway, I pretty much recently graduated, and my first duty was to design a GFCI for one of our inverter designs.
First thing I did is open an existing GFCI circuit too see how they do it. I quickly noticed the double toroid design, this confused me greatly! I'm confused about sensing the ground-neutral fault condition.
you can see examples of this design here, and here
http://www.fairchildsemi.com/ds/RV/RV4141A.pdfhttp://www.ti.com/lit/ds/symlink/lm1851.pdf(go to typical application circuit)
Ok, so here is how I think the double toroid circuit works. the ground-nuetral sense transformer (one with 200 windings in both drawings) has one primary connected to the AC line voltage. It also has to secondaries, hot and neutral. this transformer imparts a voltage of (max ac)/200 on both hot and neutral wires. if neutral is connected to ground, this induces a current, which is picked up by the current sense transformer. if neutral is not connected to ground, no current is induced.
this site explains it pretty well
http://www.rhtubs.com/GFCI/GFCI.htm.Is my guess (and the websites explanation) of how the double torioid sysytem work correct?
further more, if a ground-neutral fault is large enough, it SHOULD be picked up by the primary sense transformer no? the second transformer (neutral transformer) is for extra safety? In my mind, the second ground-sense transformer _increases_ the differential current to be sensed, but without it, in the case of a ground-neutral fault, this differential current would still exist?
Thanks for the help guys and gals!
