Author Topic: good books on vacuum tube design?  (Read 17348 times)
Offline sarepairman2Topic starter
« on: January 27, 2016, 02:27:24 am »
Offline Alex Eisenhut
  • Place text here.
Re: good books on vacuum tube design?
« Reply #1 on: January 27, 2016, 02:41:36 am »
How to design the tubes themselves? Or *with* tubes? Design *what*? Audio amplifiers in the single digit watt range? Kilowatt range? RF amplifiers? Photomultipliers? Microwave stuff? Backward wave oscillators to the THz range?
« Reply #2 on: January 27, 2016, 03:29:31 am »
physics level vacuum tube stuff
  • Place text here.
« Reply #3 on: January 27, 2016, 03:36:49 am »
The RCA receiving tube manual is good.
http://www.tubebooks.org/tubedata/RC30.pdf
There's probably a MIT Rad Lab volume on that too.
Online joeqsmith
« Reply #4 on: January 27, 2016, 03:40:36 am »
First suggestion without knowing what you are looking for:
ARRL Handbooks, something pre 1960s
RCA Receiving Tube Manual
If you really want to see some good info, try and find a copy of:
Applications Manual for Computing Amplifiers for Modelling Measuring Manipulating & Much Else
It's more an analog designers guide with a sprinkle of tubes....
« Reply #5 on: January 27, 2016, 03:45:28 am »
thank you, that is a good start
i think i have an idea that might bring the vacuum tube back to life
Offline AF6LJ
« Reply #6 on: January 27, 2016, 03:51:22 am »
I second that  :-+ :-+ I have it in both hard, and soft copy.
Very useful, not just for the theory, there is an application section in the back.
Sue AF6LJ
Offline HAL-42b
« Reply #7 on: January 27, 2016, 03:58:55 am »
Mike used to have a very good one on his site, don't know if he still keeps it there.
Gas Discharge Tubes - Dr J. G. W. Mulder.
Offline AF6LJ
« Reply #8 on: January 27, 2016, 04:03:26 am »
Another good suggestion is Bill Orr's Radio handbook.
In some respects better than the ARRL Handbooks.
Sue AF6LJ
Offline chris_leyson
  • Country: wales
« Reply #9 on: January 27, 2016, 05:34:39 am »
A few that spring to mind, all on my bookshelf, but 200 miles away  :(
The Radiotron Designer's Handbook by J. Langford-Smith, It was reprinted a few years ago, can't find the ISBN number grrr
Universal vade-mecum if you want data sheets still available I think
Valve Amplifiers by Morgan Jones, might still have that, dunno
Principles of Electron Tubes, Herbert Reich 1941 - A classc. Can't find a copy of that one, seems the audiophiles grab those.
Just found a scanned copy  :-+ check links below, i know what I'm going to be reading this weekend  :)
http://www.qsl.net/va3iul/Files/Old_Radio_Frequency_Books.htm
http://www.tubebooks.org/technical_books_online.htm
Offline daqq
  • Country: sk
    • My site
« Reply #10 on: January 27, 2016, 05:51:50 am »
Philip Parker : Electronics, 1950
I don't know if you can find it online, I have a paper copy. If you run into one copy, definitely buy it. See:
https://www.eevblog.com/forum/chat/1950s-book-copyright-can-i-scan-this-and-upload-it/
Offline Pjotr
« Reply #11 on: January 27, 2016, 07:19:28 am »
For the real physics of vacuum tubes there are several good pre WW2 books. For that you need to go to the library of the physics department of a (technical) university. Some of those books have nice pictures that illustrate the static fields in a tube with the use of rubber sheets... I have not found such material on the web.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #12 on: January 27, 2016, 06:46:23 pm »
Some from my shelf:
Vacuum Tubes - Karl Spangenberg - 1948
Electronic Circuits and Tubes - Cruft Electronics Staff - 1947
Vacuum Tube Circuits - L. B. Arguimbau - 1948
And of course the aforementioned Radiotron Designer's Handbooks.
-Pat
Offline Cubdriver
  • Nixie addict
« Reply #13 on: January 27, 2016, 06:51:48 pm »
This one seems to be available as a reprint as of 2013 in both soft and hardcover on Amazon.  I'll be looking into it...
http://www.amazon.com/Principles-Electron-Tubes-Herbert-Reich/dp/1258664062/ref=tmm_hrd_swatch_0?_encoding=UTF8&qid=1453920562&sr=8-1
-Pat
Offline oldway
« Reply #14 on: January 27, 2016, 07:24:15 pm »
The Radiotron Designer's Handbook by J. Langford-Smith, It was reprinted a few years ago, can't find the ISBN number grrr....
I have the Radio designer's handbook fourth edition by F. LANGFORD-SMITH
First published (Australia) : 1934
Second edition : 1935
Third edition : 1940
Fourth edition: 1953
BKS1635/53
Offline uncle_bob
« Reply #15 on: January 27, 2016, 07:31:34 pm »
Hi
As in the physics of how to do the insides of a vacuum tube.
Are you planning to run a hot cathode or not?
Bob
« Reply #16 on: January 28, 2016, 12:31:20 am »
Hi
Bob
i have no idea, I have a fair bit of reading cut out for me with all these posts, maybe i can tell you in a month lol
Offline Stray Electron
« Reply #17 on: January 28, 2016, 02:43:21 am »
   'Gaseous Conductors' by James D. Cobine, McGraw Hill, 1941.  It's one of those good OLD text books that really teaches you the theory and the practice. But good luck finding a copy. It took three years for me to find one and I had buy someone's entire library to get it!  Despite the slightly misleading title, it goes into the characteristics of fluorescent lights, vacuum and partial vacuums, inert gasses, hydrogen gas (thyratrons), Mercury vapor, etc as well as the nature of the anode and cathode and space charge. Unlike radio tube books that deal with VT amplifiers and the like, this book covers every aspect of electron flow inside of tubes under many different circumstances. They do discuss radio type tubes but that is just one single use.
Offline HAL-42b
« Reply #18 on: January 28, 2016, 03:24:02 am »
« Reply #19 on: January 28, 2016, 03:28:08 am »
this sounds like exactly what I am looking for.
I find some of the old texts extremely good, they give you the information in a manner that it is much easier to detect the concept, because it is not obfuscated by too many profitable applications
maybe the old authors were more excited by the stuff too
is this it? http://product.half.ebay.com/Gaseous-Conductors-Theory-and-Engineering-Applications-by-James-D-Cobine-1941-Paperback/48999312&tg=info
« Last Edit: January 28, 2016, 03:31:39 am by sarepairman2 »
  • Place text here.
« Reply #21 on: January 28, 2016, 07:36:31 am »
ok i bought that old book  :-+
i think i will start with that low level physics book governing the gas behavior before i get into the other literature
Offline uncle_bob
« Reply #22 on: January 28, 2016, 06:27:14 pm »
Hi
Bob
Hi
Well, it's one of many very big differences in which way you go with this. I've worked with a number of tube designers. They tend to specialize fairly early in their training and spend the next 5 or 10 years learning the trade in their sub-area.
More or less:
Hot cathode vacuum based tubes are one area.
Gas filled (power) tubes are a different area
Cold cathode devices are a different area still
Each has it's application. Each has it's own physics. Each has a specific type of manufacturing plant designed to make them. There are indeed many further sub specializations. A tube for an audio pre-amp is a bit different than the output tube in a 100KW transmitter. Both are vacuum tubes with hot cathodes. The guys who design one are not the same as the guys who design the other ones. Same is true of the manufacturing lines.
It might help if we had some idea of what you are trying to do. Tubes get (or got) used in a *lot* of things ....
Bob
Offline Paul Rose
« Reply #23 on: January 28, 2016, 11:51:02 pm »
If it comes to circuit design with existing tubes/valves (not development of the devices themselves), I've been meaning to look at:
"Hollow State Design" by Grayson Evans ( ISBN 978-1300965213 )
It is actually a recent book ( 2013 ).
Somewhat oriented toward radio amateurs ( RF and Audio ).
« Reply #24 on: January 29, 2016, 12:49:06 am »
    That looks like it. I didn't know that Dover had reprinted it but they have reprinted other classic text books such as the MIT Rad Lab series.
