Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
good quality solderable 3.5mm headphone plug
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: good quality solderable 3.5mm headphone plug (Read 941 times)
Alex Eisenhut
Super Contributor
Country:
Place text here.
on:
May 25, 2018, 03:22:07 am »
I repair my broken headphones and I like the look of these connectors
https://www.ebay.ca/itm/Gold-3-Pole-3-5mm-Male-Repair-headphone-Jack-Plug-Metal-Audio-Soldering-Spring/281243011459?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
the quality leaves much to be desired. Hard to solder to, no secure gripping of the cable (it'll break the fragile connections instead of yanking the plug out of the jack), and the sleeve thread is terrible, it barely engages the thread and after soldering the wires it doesn't engage the thread at all anymore...
The headphone cable I use is 1.9mm (75 mils) in diameter, it's round, not the side-by-side type.
I could buy the whole cable pre-built
https://www.ebay.ca/itm/3-5mm-Jack-DIY-Earphone-Headphone-Audio-Cable-Repair-Replacement-Cord-Wire-120CM/272902028155?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D40972%26meid%3D45a912277ee347c6be548019fbc44022%26pid%3D100005%26rk%3D5%26rkt%3D12%26mehot%3Dpp%26sd%3D232525442262%26itm%3D272902028155&_trksid=p2047675.c100005.m1851
buuuuuuuut then I have the extra work of cracking open two shells and reworking the connections there, and I don't get to choose the length to the split. etc etc etc....
Yes I'm complicating things. I enjoy that!
Soooo.... any recommendations? Yes I tried the Neutrik 90 degree adapter and it's not that great either. Easier to solder to but doesn't work well with my cable thickness. The grommet is meant for a much thinner cable.
Logged
DaJMasta
Super Contributor
Country:
Re: good quality solderable 3.5mm headphone plug
Reply #1 on:
May 25, 2018, 05:58:08 am »
It's a no frills option, but I recently got a few Neutrik REAN 3.5mm connectors which work well. Your normal solder lugs, all metal construction, a crimp strain relief, and a little insulating tube to keep from shorting to the housing. I think I spent like $6 or 8 (US) for 4 of them on ebay
http://www.rean-connectors.com/en/products/35-mm-plugs/nys231
Logged
http://www.medpants.com/
- W3BSN
JohnnyMalaria
Super Contributor
Country:
Reply #2 on:
May 25, 2018, 06:15:34 am »
I've used this kind for years for TSR balanced cables which get yanked in and out a lot:
https://www.radioshack.com/products/radioshack-standard-phone-plug-3
(yup, RadioShack
Shipping will hit you though unless you can find other items you need.
Logged
BrianHG
Super Contributor
Country:
Reply #3 on:
May 26, 2018, 01:39:09 am »
A goo thick heavy pure gold plating does help with longevity and quality of connection, as long as what you are plugging it into is also well gold plated.
Logged
__________
BrianHG.
https://github.com/BrianHGinc
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
