You should check out
http://www.surplusshed.com/ - surplus dealer specializing in optics.
As other have said, normal glass and plastic lenses should work fine at "near IR" wavelengths, with slightly different focal lengths; you only need exotic materials when you start talking about "thermal" wavelengths (and also want to filter out the visible wavelengths.)
I used to do some experiments with 35mm Infrared photography: Kodak has/had a film sensitive to IR that you could get in most camera stores, and process with normal chemistry. It worked fine with normal cameras with normal lenses.
(I'll also add that there is a pretty significant market in used camera lenses on eBay/etc (and in many general purpose technical surplus stores.) Now that everyone wants digital cameras with super-zoom lenses, the old film camera fixed FL lenses are selling for pennies on the dollar. Why fiddle with simple glass when you can buy high-quality optics with focus rings, arperatures, and mounting hardware for similar prices?)
(Finally, the little plastic lenses found in disposable cameras are apparently pretty good...)
