I would like to use XM1100 GPS module in one of my project. It has a 1pps output.
I would like to distribute this signal to two separate modules. Which buffer should I use for this purpose??
IF i use an ordinary buffer with wont is affect the jitter characteristics of ipps.
Are there sophisticated buffers available which can have very low propagation delay across o/p pins.
