Hi Steve,
chked out your tip ..... to enter the $PROCEED msg.... in between the $GETVER boot msg and finally I had success....!!!!
the very same time the motherboard small greeen LED was on and the current consumption was about a good 30mA higher....
total 270mA @ +12Volt... also entered the $SURVEY command and the unit started to find its position......
It is quite tricky the timing when you want to enter a new command....!!!
The unit is doing the SELFSURVEY for a good 8 hrs....right now ....... and the 10MHz RF output seems to me also OK compared to my Rubi GPSDO. / True-Time XL-DC / but need more time to chk the ADEV plot.
What other input command is important to enter in order to obtain the max precision from this little gadget
I want to use the unit only as a board the same location and just starting from a PC via RS-232 port and let is run for the next 200 years...
Is it any chance to use a PIC to this unit and after power-up the PIC going to load the $PROCEED msg and then it,s going to work.....
Sorry about the to many question .......
Cheers, Ernie.
