Author Topic: Green,Light and portable Lizard Trapper  (Read 4040 times)
Offline hiiniwenTopic starter
  • Country: my
« on: December 03, 2017, 06:28:28 am »
Good afternoon, my fyp title is Green light and portable lizard trapper. Is it possible to design a circuit that using sensor without coding by using IR sensor to generate an electric shock. And how the design of circuit need to be conduct? My idea is to make a hardware which turn on by DC supply like battery, and use LED to attract insect hence attract lizard. When Lizard trap into the device, then the IR sensor sense the lizard, then the whole circuit start to run and generate electric shock to kill the lizard. is it possible?
« Last Edit: December 06, 2017, 07:41:59 am by hiiniwen »
Offline andtfoot
Re: Green,Light and portable Lizard Trapper
« Reply #1 on: December 03, 2017, 09:33:30 am »
A couple of things:
- You wouldn't easily be able to tell whether it's a lizard in the trap, or some other animal/person's hand/etc.
- Why would you want a kill a lizard?
  • Country: my
« Reply #2 on: December 03, 2017, 10:30:42 am »
sometime it is because of the hygiene problem , and lizard sometime brings the virus that is harmful t the baby health. So is it possible for me to use a sensor without using coding? or do  you have any suggestion?
Offline DTJ
« Reply #3 on: December 03, 2017, 12:53:43 pm »
Just catch the lizard on a piece of paper or in a cup and put the poor thing outside?
I'm not sure babies catching viruses from lizards is a big issue.
  • Country: my
« Reply #4 on: December 03, 2017, 02:40:31 pm »
so do you know any sensor that can be used to sense the lizard without using coding?
Offline hermit
« Reply #5 on: December 03, 2017, 09:32:33 pm »
How big are the lizards?  I'd think common mechanical devices would be available and much simpler.
Offline cdev
« Reply #6 on: December 04, 2017, 12:23:06 am »
It seems to me that a lizard trap would likely be very similar to a mouse or rat trap. If I were you I would just search for a better mouse trap.
Also, electricity isn't a good idea for any kind of trap, especially if there are children (or grownups for that matter) around.
 Electric shock causes involuntary muscle constriction that could easily cause serious injury or death to people or pets.
Some lizards, such as monitor lizards (such as the Komodo Dragon  https://en.wikipedia.org/wiki/Komodo_dragon from Indonesia) can be aggressive and quite dangerous when grown up. They are carnivorous, and may eat up to 80% of their own body weight in one meal.
« Last Edit: December 04, 2017, 12:31:57 am by cdev »
Offline DTJ
« Reply #7 on: December 04, 2017, 01:01:11 am »
For a Komodo dragon you could put a crocodile trap in your lounge room and bait it with half a sheep.
The following users thanked this post: Sparker
Offline Cyberdragon
« Reply #8 on: December 04, 2017, 01:15:35 am »
I think he's talking about those little geckos that crawl all over your walls. They're pretty harmless, you don't need to fry the cute little critters, just trap them in a funnel trap or something like that and dump them outside. The bigger question is how they're getting inside, try sealing up cracks and things, before you get something worse creeping in like rats.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline Silveruser
« Reply #9 on: December 04, 2017, 02:08:52 am »
If I remember my biology correctly lizards are cold blooded ie thier body temperture is at or near ambient. An IR sensor might not work all that well by itself. Maybe with an IR LED and breaking a beam might work. What is the visible range of these creatures? Can they se into the IR spectrum?
The following users thanked this post: hiiniwen
  • Country: my
« Reply #10 on: December 04, 2017, 02:27:24 am »
just a small gecko
Offline Cyberdragon
*BZZZZZZAAAAAP*
Offline cdev
« Reply #12 on: December 04, 2017, 03:18:34 am »
One family in Thailand keeps a crocodile "Kheng" as a family pet!
http://news.bbc.co.uk/cbbcnews/hi/world/newsid_2224000/2224129.stm
It would never hurt them, it's never killed anything.
Online paulca
« Reply #13 on: December 05, 2017, 04:58:47 pm »
I know a sensor that does not require coding that will probably deal with you issue.
« Last Edit: December 05, 2017, 09:33:04 pm by paulca »
Offline james_s
« Reply #14 on: December 05, 2017, 08:29:36 pm »
Do you really want to deal with the smell of electrically cooked lizards? Wouldn't it be easier to use a glue trap or even a non-lethal trap they crawl into and can't get out?
  • Country: my
« Reply #15 on: December 06, 2017, 07:41:38 am »
what is that sensor?
« Reply #16 on: December 06, 2017, 07:54:33 am »
It's a cat
Sent from my SM-J510FN using Tapatalk
Offline DTJ
« Reply #17 on: December 06, 2017, 08:09:47 am »
Glue traps are inhumane. Don't use them.
Offline env23
  • Country: ph
« Reply #18 on: December 06, 2017, 08:57:14 am »
I have two cats. Since I got them I never see a gecko any more. They finished them all. Before every wall used to have one at least. I miss them a bit.
Offline james_s
« Reply #19 on: December 06, 2017, 04:36:01 pm »
Less humane than using electricity to potentially slowly cook them to death?
A cat has always been my preferred method of pest control. They make good company too.
« Reply #20 on: December 06, 2017, 06:29:50 pm »
Had a pair of geckos doing the old bit of making out one day, on the pole of the electric fence. The guy had his tail touch the live wire, and  the lady was the ground as she had all feet hanging on to the grounded steel post. As he tripped the fence they went out with quite a bang, were still twitching with the pulses when I came out 20 minutes later to find what was triggering the fence.
Offline Kleinstein
« Reply #21 on: December 06, 2017, 07:40:07 pm »
When you are afraid of viruses and similar, a cat is not such a good idea. Cats do spread viruses and other nasty stuff - likely more than lizards. Usually not many viruses effect mammals and cold blooded lizards. It might even help to have a few geckos to reduce the insects - which are more likely to cause trouble.
When I was in the US, they liked to have a rattle snake around to keep away the mice, as some mice where spreading a very nasty virus. A different type of snake would be OK too.
Offline apelly
  • Probe
« Reply #22 on: December 06, 2017, 07:41:53 pm »
Once it's pointed out, the solution's obvious!   :D
Offline Audioguru
« Reply #23 on: December 07, 2017, 02:05:58 am »
No lizards here but we get racoons, squirrels and chipmunks. The experts say that possums are coming and will take over from the racoons. I saw one possum on my fence. There are deer in the forests.
I have never seen a rat but I saw a couple of mice far from my home. No snakes and no lions. The signs say there are coyotes in the parks at night but I have never seen one.
Offline cdev
« Reply #24 on: December 07, 2017, 01:07:11 pm »
In the islands where Komodo dragons still live alongside humans they periodically sacrifice a live goat or deer to the dragons.  An ancient ritual.
Similar to the "Wicker Man" in the UK.
(Christopher Lee's favorite role.)
