Hallo guys and girl,
I finally decided to make myself useful in the forum
From time to time I release youtube videos about electronics or other stuff that I like, but sometimes you need to work from your
PC / Laptop to make a video. With the integrated microphones of my laptop being rather inefficient for producing a pleasant sound,
I borrowed a Behringer mixer and microphone from a friend. Unfortunately every time I connected it to the laptop (either input/output),
it would become noisy. Reading around the internet and after some research I found out that it´s a grounding problem and a ground
loop isolator was needed. Unfortunately everything that has the word audio in it, and it is not a horrible Chinese product is expensive.
So, I said to myself... Why not design one myself! And I did!!!
I have no interest in earning money from it so I release it here open hardware
Here´s the specs:
Input ~3Vpk-pk (MAX)
Output ~3.5Vpk-pk (MAX)
Flat baseband from 10Hz to 20kHz with ~1.5db of gain.
I have NOT built it yet and not tested it in real world (only sim.), but should work nicely.
Another thing. I don´t know how lineal 4n27 is. I biased it at 5mA and it´s working pretty much like
a class A amplifier. Another good thing is that the design is working from a single 5V rail when you
want to experiment with it!
I´ve built everything in just 4 - 5 hours so if I missed anything please have mercy!
I hope you like it and that someone might find it useful!
Best Regards, Lefteris
Thessaloniki, Greece
P.S. If there is someone who is willing to build it, I will upload the schematics and board. The project is built using Eagle 6.3.0..
