But why mention it at all, especially as a headlined feature ...
I wouldn't worry about that rude reply, maybe he ate a bad muffin :-) What you say is reasonable, and you'd THINK manufacturers would
go out of their way to make
sure datasheets were concise and correct, after all, they're trying to make you buy their product, and they KNOW that people reading them aren't regular dummies.
Unfortunately,
many datasheets have errors, some serious. Sometimes they do it to make their part
look good, and hope you ignore the errors.
Sometimes, they just don't proof read properly, or use a generic templates. It's VERY common to find errors.
My biggest b*tch is with SOA regions of Power Mosfets (used in linear mode). Not one has an accurate (or realistic) graph. I spend days creating realistic ones.
On top of these, they don't always get the dies as expected, or repeatable, or switch to a new fab and things go out-of-tolerance. Often it's easier to shaddup :-)
... And why use the phrase 'extremely low offset' rather than 'no offset' or 'zero offset'? .... irrelevant standout features in datasheets isn't that common. Is it?
As before - very common
Edit: And it can be much worse ! In one project for a Solar EV BM system, we spent great effort in chosing
perfect components. Then I made up several units,
and had others writing code. Turned out the INA198 current sense IC was completely non-linear (and non-repeatable) at the lowest 15-20% of it's curve.
$1,000s of time and parts wasted. It wasn't even CLOSE to the graphs supplied, including white papers. Moral : DON'T trust spec sheets implicitly !!
