Anyone here design anything to be cooled or heated using heat pipes? I'm working on a project that uses Peltier modules to heat or cool and the temperature difference you can achieve between ambient and the device is a function, among other things, of how well you can remove heat from the hot side of the module. A measure of that would be the difference in temperature between the hot side of the module and the free air temp and a more efficient cooling of the hot side will permit a lower temp on the cool side as well as higher cooling power.
The thing is ... a really good Peltier module is kind of pricey and it will still need a good heat removal system to function well. If a modestly more expensive heat removal system using heat pipes permits using lower cost Peltier modules it might make sense to go that route.
There are really two kinds of heat pipes as best I can tell: ones with some form of wick to transport the condensed fluid back to the hot side, and the type that does not have a wick and relies on thermosyphonning. For the temp range I'm looking at (-40C to 70C) it looks like aluminum/ammonia are the materials to use. A thermosyphon approach would likely be cheaper and in my configuration I think I can depend on the thermosyphon to work though I understand bubbles will interfere with the vapor flow reducing the heat transfer to just the conduction through the Al tubing. I would appreciate any feedback on the causes and remedies of bubbles.
Just to paint a picture of what I'm looking at I envisige bonding both side to Al blocks with the hot side having heat pipes extend upwards from the block, then travel horizontally through and in contact with an fan cooled Al heatsink, then travel down below the bottom of the Peltier block, then horizontally back to the block, then upwards back to the block completing the loop. As I understand the system I need to maintain both liquid and vapor at all times and temps and that the minimum temp needs to be greater than about -60C and less than 100C when using Ammonia. Any idea on what the proper volumetric ration of vapor to liquid needs to be and at what temp this is determined?
Additionally, if I were to power the device backwards so that the hot side becomes the cold side and vis versa with the arrangement as described the heat flow should still work.
Brian
