A great thing about brushless motors is that, with the appropriate controller:
At minimum rpm they output their maximum torque.
At maximum rpm the maximum torque they are outputting is exactly what is needed to keep them turning at that rpm, ie they physically cannot go faster because of the back-emf caused by how the motors function is generating counter torque.
Incidentally this is the
kv rating: rpm = kv * V
NTM Rotor Drive 600 Series 510KV / 5500W = 44.4v = 22,644 rpm
Turnigy AquaStar T20 3T, Star wiring = 730kv @ 44.4v = 32,412 rpm
Turnigy AquaStar T20 3T, Delta wiring = 1280kv @ 44.4v = 56,832 rpm
Now with a load these motors will never reach that rpm and on some motors that speed is higher than the bearing speed which will burn the bearings out so a load is always needed to be connected on those ones.
A lower
kv rating for the same Watt means better low speed torque and more efficient at low speed assuming equivalent efficiency curves.
As for lipo's the Ah is the energy stored in the battery, the amps they are capable of of is the
C rating times the Ah rating.
So C * Ah = Amp
Random chosen:
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=495097.5 Ah
2S (3.7*#), = 7.4v
90 C
So the max amp that can be drawn is somewhere ~675 amp.
note: some batteries are listed 2
C ratings, a burst(short time) and continuous, make sure to check the continuous, sometimes they only list burst.
The energy of a lipo is: Ah * V = Wh
With the previous battery:
7.5 * 7.4 = 55.5 Wh, @ 1kW = 3 minutes and 19.8 seconds.
Another random battery:
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7409612 Ah
6S, 22.2v
10 C
Amp: 120 amp.
Energy: 266.4 Wh, @ 1 kW = 15 minutes and 59 seconds
Here's the HobbyKing lipo filter:
https://www.hobbyking.com/hobbyking/store/lithium_polymer_battery_configuration.aspRC lipo's are for high amounts of power in a small light weight package, not so much for low amounts for power but for long times, also in an electric bike you would only be using bursts for acceleration, < 40km/h you ain't going be needing much full time power.
Now moving a car on RC motors, hmm.
Gotta gear it right and with an appropriate kv rating.
Also bear in mind this is the energy
into the motor not the energy
out of the motor, RC motors are generally not designed for efficiency so left say 85%.
5.5kW * 85% = 4.675 kW
Well the energy to move a Fiat Uno at 50 km/h cruse is about 5 kW, so you fall short with 1, using 2 you get around 9.35 kW which is enough for cruse and acceleration.
Buuuuut, motor to wheel efficiency, what is that?
Lets go blindingly naive, say 2 sprockets one directly onto the axial and one one the motor, motorbike roller chain,
perfectly aligned,
clean,
lubed correctly ~98%.
9.35 * 9.35 kW = 9.163 kW, so yeah got enough when operating in motor efficient range.
Probably need a support bearing on the motor shaft end with it
perfectly aligned so you don't bend it.
Reality is less than ideal, so how much much extra do you need?
Try looking at the attached brushless curves.
