Would that be enought to move the car?
What are your speed and acceleration requirements and expected total mass?
Some kind of optimisation needed to find best solution.
Fiat Uno has not great aerodynamics, so remebrer that power needed to keep speed 70km/h will be close to ~3 x times (2.7x) higher than driving at 50km/h, while this power is propotional to ~V^3 (speed to the power of three)
From time to time testing classic car driving @ 50km/h at outside city trips while preparing for longer electric vehicle journey and what can I say-it is difficult, while at narrow streets without highways between small cities there are often many trucks which ignore of course those 60km/h speed limits and worse they sometimes try to make signals that you should drive faster, so driving at those economic speeds (I mean low RPM low power diesel engine) is a challenge, but it is doable with additional equipment like additional banners on the car and monitoring system installed at front at back to show donks which try to press you to go faster while you do not have to because of it is not highway with 100km/h minimum speed, but local road with ~50km/h limit
Conclusion is-it is possible to drive at 50km/h at my local area, so power requirements for electic vehicle can be reduced-how much it will depend on EV aerodynamics and weather conditions, while winter days can be a challenge and difficult roads with snow-additional power needed, worse bettry working condition (preheting and temperature control mich be helpfull), etc...
There are many factors which will affect EV needed power requirements, so without detailed driving requirements it is only guessing what you meant-how much power I need. My answer is it depends for reasons above
i dont want to go more then 30km/h
Ups, so this will be rather electric bicycle not EV and difficult to explaint other cars members on the road such low speed unless you add at back safety triangle meaning car failure or damage and emergency driving
