OTOH better to crowbar and risk tripping the battery protection rendering the battery pack useless, than risk serious personal injury trying to shut down a runaway flailbot or thwackbot.
You'd have a two stage emergency shutdown: first level would shut off power by the bot's normal method and also hold all ESCs and CPU boards in reset, and the second level would, as a last resort trigger the crowbar.
Its also probably worth having a rule that the main battery connector must be pluggable, with a stout loop that can be hooked onto to disconnect it, and easily accessable from the underside. Then, worst case, the bot can be flipped with a spade, and the connector unplugged with a button hook.
