I want to drive a 3w IR LED using AAs, I need a minimum of 3xAAs to power a micro.
The LED is rated 1.4-1.6v 700mA but I don't mind if I only run it at 350-500mA
I've tried using 3xAA (~4v) + a linear AMC7135 (PDF:
http://led22.ru/ledcat/ledsource/amc7135.pdf) but obviously the power wasted through the driver is more than the LED uses.
Using 4xAA (5.5v) + a small buck (mp1584) + AMC7135 is better but the AMC7135 needs 2.2v to work - it's rated at 2.7v (Vs) so it's still not very efficient. I get around 60%
Are there any small linear drivers that will run from 1.5-2v supply? The only ones I could find are the BCR321U and BCR320U but I'm not entirely sure what their minimum supply voltage is, the infineon site says 1.4v min, but the datasheet doesn't mention it. Or maybe some off-the-shelf switch mode drivers?
I think the best bet is to just get 2x3W leds in series and use 1xAMC7135 but I would rather just use 1 LED.
