There is an existing LED master and slave PCB configuration. (not my design)
The master PCB provides power and data to a slave PCB. In the design, there are four wires on a connector going from the master to the slave PCB: Power (either 12VDC or 24VDC), clock (5V), data (5V), and ground. The clock is running at 100KHz. The cable length is about 5cm.
The issue is this: If the 4 pin connector is unplugged, it sometimes damages the data/clock lines. This seems to happen when the ground is lost first. My first thought is to use Zener diodes to protect the clock and data lines, but Zener diodes have relatively high capacitance value and it tends to not get along well with the 100KHz. How should the clock and data lines be protected from the 12/24V when exiting the master PCB and entering the slave PCB?
Matt
