Yes, I am finding lots of good options. My main requirement is to separate the grounds from the digital/computer half and amateur radio/remote half mainly for RF ground loop mitigation. Absolute worst case for isolation would be a lightning strike I'd imagine, with antennas outdoors, so higher withstanding voltages are a good thing. Normal day to day operation would be serial communications to control various aspects of the amateur gear, so missing data could cause unintended operations. I've tried the 6n136 and 137 in the simulations, the 137 behaved a bit better, but still had the occasional missing pulse, and lots of switching glitch, which may or may not occur, as it is a simulation. The 136 misbehaved more often than not, with low voltage response at best, or very strange glitched signals.
