Hello.
I am developing a high-current sync. buck converter that is going to be controlled by a microcontroller, however I need to not only measure the output voltage and output current but also the load resistance which may vary between 2ohm - 0,05ohm(but if necessary it could be restricted to below 1,5ohm). The resistance measurement is going to be used to indirectly measure the temperature of the load which is a heating element made out of materials such as SS316, Nichrome, or if the design becomes good enough Kanthal A1(yes this is a design for a vaporizer chip, which is part of a project(in it's very early stage) to create a vaporizer which is open source to enable competent users to change the firmware for them selfs, there are still a lot of safety stuff to go through but I am simply the person whom have been tasked with coming up with a working prototype).
This sort of vaporizer is used to atomize liquid containing nicotine(but nicotine is optional) used as a substitute for tobacco products, the vaporiser(AKA box mod, APV, e-cigg etc) is used with a atomiser which contains heating coils through which there are cotton placed, the cotton is drenched in the liquid.
For me the most important aspect of this device(aside from safety) is it's temperature control, which functions by measuring the heating element(here after called "coil") resistance at room temperature, then power is supplied to the coil while the resistance is periodically measured, and the new resistance value, the resistance value at room temperature and a temperature coefficient for the specific material the coil is made out of is used to estimate the coil temperature.
But the device can also function in a mode in which the power is simply regulated to a set value.
In order to give a satisfactory result the resistance have to be measured many times each second, I don't really know how often is needed, I will investigate this by studying commercial chips but I thought that a sample rate of 500Hz might be a good start(I'm not sure but I would think that 500Hz would be more than enough). I haven't made the first prototype jet so let's pretend that I need 500 resistance measurements each second, how do I accomplish this?
The current is supplied by a synchronous buck converter running at 100kHz, the hole design would be much more efficient space wise if I could forget about the filter components but thus far I have concluded that such a circuit would be to complex with calculating the average output wattage, so to begin with it will be a buck converter with filter components.
The most obvious solution is a current-sense amplifier but then I get confused about the bandwidth of the amplifier which turns out is rather low in most cases.
How does the 100kHz ripple effect my current measurement?
And what is required to deal with that situation?
This application doens't exactly require a low-noise supply so thus far I have thought to tailor the amount of ripple after the current measurement, I have made a schematic but it is simply a buck converter with a current sense resistor in the series with the output after the output cap. I am not sure about how to do with the buck-converter current limit though, I am measuring the output current for the resistance measurement but in order to limit the current isn't peak current limiting required? Which requires the current to be measured before the buck-converter inductor... But lets keep focus on the resistance for now.
Regards
